Rule for naming STEP files with Prompted Texts
- Mute
- Permalink
- Report
I'd like to create a rule "like Save in STEP format" to use the Prompted Texts "Numéro du plan" in the STEP file name.
Dim doc As DrawingDocument = ThisDoc.Document Dim sheet As Sheet = doc.ActiveSheet Dim view As DrawingView = sheet.DrawingViews.Item(1) Dim partDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument ' Get current location of this file Dim ExportPath As String = ThisDoc.Path ' Check that this file has been saved and actually exists on disk If String.IsNullOrEmpty(ExportPath) Then MsgBox("This file has not yet been saved and doesn't exist on disk!" _ & vbLf & "Please save it first", 64, "Lord iLogic") Return End If Dim drawingNumber = 'the Prompted Texts "Numéro du plan" Dim dialog As Inventor.FileDialog ThisApplication.CreateFileDialog(dialog) dialog.InitialDirectory = ExportPath dialog.FileName = drawingNumber dialog.DialogTitle = "Save" dialog.Filter = "Step files(*.stp)|*.stp|All Files (*.*)|*.*" dialog.CancelError = True Try dialog.ShowSave() Catch ex As Exception Return End Try ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = dialog.FileName oSTEPTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData) End If
Thank in advance and have a nice day
