Batch export model state STL
inventor4578
Message 1 of 10
inventor4578
I try to make a bulk export of my .ipt part into .stl files with 1 .stl by Model State
But the problem is for 20 Model state, i get 4 "good" file, and 16 "1 Ko" files (bad file).
Sub Main
    Dim oDoc As PartDocument
    oDoc = ThisDoc.Document
    Dim oModelState As ModelState
    For Each oModelState In oDoc.ComponentDefinition.ModelStates
        Logger.Info(oModelState.Name)
        If oModelState.Name <> "Master" Then
            oModelState.Activate
            ExportSTL(oModelState.Name)
    Next
End Sub
Sub ExportSTL(ByVal oState As String)
    ' Get the STL translator Add-In.
   Dim oSTLTranslator As TranslatorAddIn
    oSTLTranslator = ThisApplication.ApplicationAddIns.ItemById("{81CA7D27-2DBE-4058-8188-9136F85FC859}")
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    oPath = ThisDoc.Path
    oFolder = oPath & "\MODEL_STATES_STL"
    'Check for the STL folder and create it if it does not exist
    If Not System.IO.Directory.Exists(oFolder) Then
        System.IO.Directory.CreateDirectory(oFolder)
    If oSTLTranslator.HasSaveCopyAsOptions(ThisDoc.Document, oContext, oOptions) Then
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oData As DataMedium
        oData = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = oFolder & "\" & ThisDoc.FileName(False) & "-" & oState & ".stl"
        oSTLTranslator.SaveCopyAs(ThisDoc.Document, oContext, oOptions, oData)
End Sub
Replies (9)
Message 2 of 10
Frederick_Law
What's wrong with the bad file?
Message 3 of 10
inventor4578
Bad files are empty (1kb)
If i open the file with notepad i just have 1 line : "STLB ATF 10.19.0.1499", that all.
I tryed on another part, it seam to work ? That strange ?
Message 4 of 10
Frederick_Law
Can you manually export STL on those failed parts?
Check and set options for export:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-25D24E28-7517-4903-8AEE-123F8C71A89E&v=In...
Export as ASCII.  Some slicer has problem reading Binary.
Also some slicer can read STEP.
Assuming you're 3D printing them.
Message 5 of 10
WCrihfield
Hi @inventor4578.  In addition to what @Frederick_Law said about trying manual process and setting some of the options when doing it by code, I would suggest that you avoid using the 'ThisDoc' term within your ExportSTL Sub routine, and consider passing the value of the ModelState.Document property to the ExportSTL Sub routine, instead of just the name of the ModelState.  Then use that supplied Document object, instead of 'ThisDoc.Document' phrase in those two methods within that routine.  Using ThisDoc.Path and ThisDoc.FileName(False) would likely be OK, because it will be the same for all ModelStates because they are all in the same file.  I am guessing that the term ThisDoc may keep referring to the originally active document reference though, instead of the document associated with the currently activated ModelState while you are looping through them and activating them, which would be a problem.
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 10
inventor4578
Hi.
It's working with manual export ASCII, with my STEP macro is working also for all the model states.
Message 7 of 10
BM_Ashraf
I think the process is too fast and you need to update the document before you export the .stl files
check this one
Sub Main
			InventorVb.DocumentUpdate()
    Next
End Sub
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
Message 8 of 10
inventor4578
Hi, thank for reply ! I test it
Message 9 of 10
BM_Ashraf
is it possible to share the test file ?
Blue Mech
Message 10 of 10
inventor4578
Now it's working, all files are good.
Thank you very much,
