Delete all except selected outcome from multi-value parameter
david.tunnard
david.tunnard
Hi all,
Im hoping this should be failry simple.
I have a multi-value list which has, for example, 'Part A', 'Part B', and 'Part C'
If Part A is chosen then it gets added to the assembly, I would then want to delete the other two options from the assembly (if they are in it).
At the minute I am just doing a variant of the following:
If example = "Part A" Then
	Dim componentA = Components.Add("Part A", "Part A.ipt")
	Components.Delete("Part B")
	Components.Delete("Part C")
 Is there a better way to do this?
A.Acheson
Hi @david.tunnard
If your using a multivalue parameter then this is an arraylist, see ilogic help page here . So what you can do is loop through this arraylist like so and do something with the string value.
For each val As String in MultiValue.List(“example”)
     Else
        Components.Delete(val)
Next
Regards
Alan
