Rule compile errors in {rulename}
AlexFielder
Advisor Advisor
Message 1 of 11
AlexFielder
I have an iLogic rule that I've amended over the course of several months. I am supposed to hand it to my customer for them to use shortly.
Last time I checked, the rule was running correctly. (In December of 2018!)
Now when I attempt to run it I am presented with this:
2019-01-29 14_35_01-Rule Compile Errors in SaveAs_PDF_(Single_Or_Multi-sheet), in G0918-07 FOLDING T.png2019-01-29 14_34_22-Edit Rule_ SaveAs_PDF_(Single_Or_Multi-sheet).png
What the "F" is going on? Every time I attempt to run the rule the "missing file" is a different .dll file.
Replies (10)
Message 2 of 11
bradeneuropeArthur
please upload the code!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
AlexFielder
I just found the solution to this and I figured it is worth sharing:
When this error occurs, as you can see in the above error message it points to the %temp% folder.
Within this folder Inventor creates the following randomly named files:
Because I was curious as to what these files contain, I opened a couple of them and the result came in one of the *.out files thus:
2019-01-29 14_44_49-C__Users_Alex.Fielder_AppData_Local_Temp_njkldpg4.out - Notepad++ [Administrator.png
So changing the highlighted line above from this:
For Each oTextBox as TextBox In oTitleBlock.Definition.Sketch.TextBoxes
To this:
For Each oTextBox as Inventor.TextBox In oTitleBlock.Definition.Sketch.TextBoxes
fixes the issue.
I thought this kind of error would have been picked up within the iLogic window itself, but apparently not.
Is that asking too much or on the "To-Do" list somewhere?
Is this behaviour documented in a help file/page because it should be if not, yes?
Message 4 of 11
bradeneuropeArthur
Actually this is programming basics.
This is solved with:
Using Inventor
imports inventor
in the start of your modules.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
I need Help with the same issue. I only have one computer in my department that cannot use the code I created. He gets the same error as the other guy. Please help to solve this. I need this guy to use I-logic and I have tried everything to get this to work.
Message 6 of 11
bradeneuropeArthur
Hi @Anonymous ,
Please upload your complete code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
It's not the code. we have several other computers using the same version of inventor (2015) with no problems. And On the one that is messed up, it is any/all I-logic. from the simplest code to launch a form upon opening the model to something like this:
If Header_NPS=.5 Then
Header_OD=.84
Else If Header_NPS=.75 Then
Header_OD=1.05
Else If Header_NPS=1 Then
Header_OD=1.315
Else If Header_NPS=1.25 Then
Header_OD=1.66
Else If Header_NPS=1.5 Then
Header_OD=1.9
Else If Header_NPS=2 Then
Header_OD=2.375
Else If Header_NPS=2.5 Then
Header_OD=2.875
Else If Header_NPS=3 Then
Header_OD=3.5
Else If Header_NPS=3.5 Then
Header_OD=4
Else If Header_NPS=4 Then
Header_OD=4.5
Else If Header_NPS=4.5 Then
Header_OD=5
Else If Header_NPS=5 Then
Header_OD=5.563
Else If Header_NPS=6 Then
Header_OD=6.625
Else If Header_NPS=8 Then
Header_OD=8.625
Else If Header_NPS=10 Then
Header_OD=10.75
Else If Header_NPS=12 Then
Header_OD=12.75
Else Header_OD=Header_NPS
Simple parameter modification. Most of the crew does not touch complex code. I do not know why the computer is the only one messed up and how to ix it. Any help to solve this issue would be appreciated.
Message 8 of 11
bradeneuropeArthur
hi,
Maybe the regional settings!
point and comma!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
Where would I check this? And if that doesn't work do you have any other suggestions? You suggested above that this could be solved through inventor. I was hoping that complete uninstall reinstall would solve the issue. It has not.
Message 10 of 11
bradeneuropeArthur
in windows start>>
type region...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
The regional settings are the same on each computer.
