Round Dimensions-Table Parameter
iva.btblan
iva.btblan
I would like to round out the values of the parameter table.
I don't want to change the dimensions of the 3d model.
I just want to round the values to be used in other formulas, I can not use broken number.
These values have to be always round or for less or for more.
Could someone help you understand that?
Iva.btblan
bradeneuropeArthur
Use Ceil und Floor in your formulas ie
Param1 = 123.1234 ul
Param2 = Ceil (Param1) >>> 124 ul
Param2 = Floor (Param1) >>> 123 ul
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
iva.btblan
Thanks for the help!
I didn't understand your answer.
I'm sending you the file.
Please, you could perform the content sent in the attached file.
This way I can understand.
Thank you.
bradeneuropeArthur
See picture:
If you need further assistance please let me know.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
iva.btblan
Excellent!  I understood perfectly.
Thank you very much.
bradeneuropeArthur
Sometimes things are simpler then programming.
Thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
