Inventor API support for 3d Annotations
guilloryt
Message 1 of 8
guilloryt
Morning,
Does the Inventor api have any methods/support for manipulating 3d Annotations with code?
If not are there plans to add support and when might we expect it?
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@guilloryt,
Hoping that below blog articles would help to manipulate 3D annotations.
http://adndevblog.typepad.com/manufacturing/2018/02/getting-modelfeaturecontrolframes-in-partdocumen...
http://adndevblog.typepad.com/manufacturing/2018/03/adding-modelfeaturecontrolframe-in-partdocument-...
To investigate further, can you please provide sample file and mention 3D annotation to manipulte? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
guilloryt
See attached.. are there api methods to edit content on Text, Precision/Tolerance and Inspection Dimensions tabs of the Annotation's Edit Dimension dialog?
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@guilloryt,
Try below VBA code to set deviation to 3D model annotation.
Sub Main()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim compDef As PartComponentDefinition
    Set compDef = oDoc.ComponentDefinition
    Dim oLinear As LinearModelDimension
    Set oLinear = compDef.ModelAnnotations.ModelDimensions.LinearModelDimensions.Item(1)
    Dim oDef As LinearModelDimensionDefinition
    Set oDef = oLinear.Definition
    'If unit is not specified after tolerance value, then default unit 'cm' is considered.
    Call oDef.Tolerance.SetToDeviation("0.05 in", "0.05 in")
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
guilloryt
Would there be API methods to promote model dimensions to 3d annotations and/or to manipulate the position fo the 3d annotations after they are created?
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@guilloryt,
Hoping that above same question is answered in the below forum discussion.
https://forums.autodesk.com/t5/inventor-customization/api-support-to-promote-model-dimensions-to-3d-...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
mcgyvr
@chandra.shekar.g  Do you have an example (if its possible) on how to create "General Note" annotations in a model including defining the quadrant and the actual text of the note?
Message 8 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@mcgyvr,
Unfortunately, Inventor API do not support to create Generals notes in part document. Please log a wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
