CreateHighlightSet on sub-assembly geometry
Hi All,
Just looking for a pointer on creating a highlight set on a component occurrence within a sub-assembly.
What I am doing is getting the entities attached to a constraint in the sub assembly and trying to highlight the geometry to show the user which faces etc. are involved in the constraint.
I have tried several different ways of creating a proxy object but it throws an error every time. I had thought I was creating the proxy at the wrong level but I've tried calling the 'CreateGeometryProxy' method on the main assembly, sub assembly, leaf occurrence but nothing seems to work.
Please advise on the correct procedure given the model below. I would like to highlight face A and B while in the Main Assembly
Main Assembly
     Sub Assembly
         Leaf Occurrence One
             Face A
         Leaf Occurrence Two
             Face B
oHighlightSet = InventorApplication.ActiveDocument.CreateHighlightSet
oHighlightSet.Color = InventorApplication.TransientObjects.CreateColor(255, 0, 0)
Dim oTemp As Object
Dim oCompTemp As ComponentOccurrence
Dim oGeomTemp As Object
oGeomTemp = oConstraint.EntityOne
oGeomTemp = oGeomTemp.NativeObject
oCompTemp = oConstraint.Parent
oCompTemp.CreateGeometryProxy(oGeomTemp, oTemp)
oHighlightSet.AddItem(oTemp)
Thanks in advance
Phil
COLINBRUSCHI
This is an old post, but since it went unanswered and I recently wanted the same outcome...
For Each compOccurrence As ComponentOccurrence In docOccurrences    'get all top level occurrences
If compOccurrence.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
    For Each oEdge As Edge In compOccurrence.SurfaceBodies(1).Edges 'get all edges if its a part
        oEdgeCollection.Add(oEdge)
    Next
ElseIf compOccurrence.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then     'first get all parts, then get all edges of those parts
    Dim occurrenceDoc As AssemblyDocument = compOccurrence.Definition.Document
    Dim oEdgeProxy As EdgeProxy     'proxy between subassembly geometry and top level assembly
    For Each subOccurrence As ComponentOccurrence In occurrenceDoc.ComponentDefinition.Occurrences  'get all subassembly parts
        If subOccurrence.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then     'must be a part doc
            For Each oEdge As Edge In subOccurrence.SurfaceBodies(1).Edges  'get all edges of part
                Call compOccurrence.CreateGeometryProxy(oEdge, oEdgeProxy)  'create proxy
                oEdgeCollection.Add(oEdgeProxy)
            Next
    Next
Next
