Rotating user coordinate system
j.haggenjos
Message 1 of 1
j.haggenjos
Hello all,
Recently, I found out that one of our assembly template is using a different coordinate system orientation as our other templates. We use the "Y" axis as the vertical axis and for a while this wrong template was using the "Z" axis for the vertical axis.
I couldn't find it... But is there an "easy" way to rotate the coordinate system of an assembly, including the constraints to fix all those wrong assemblies quickly?
I think I could code something to do it with the API. However, I'm not convinced coding it from scratch would be faster than just doing it manually, we only have a handful of wrong assembly. Maybe someone as done something similar already and is willing to share his code?
Replies (0)
