Custom variable table
S7RM7RPR
S7RM7RPR
I'm having a heck of a time trying to figure out how to make a stupid automatic table. I've been trying to use the Inventor API help but it seems all the code examples are outdated and I can't get it to work.
So instead of showing off the code I can't get to work, I'll show what I need and hopefully someone can help me to get there. (should be attatched)
What I seem to be having trouble with is putting in the cell values. I can generate a table, but I can't get my values in for some reason.
I need to be able to support up to 24 different spider items.
Thanks in advance. I have no programming training so I'm learning on the fly with this otherwise I'm sure I would have been able to figure out what's going wrong.
Hi ajknextlang
What is your code?
S7RM7RPR
This is the code I can get to work.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'  the column titles
Dim oTitles() As String = {"SPIDER","IMB","PROCEDURE","'A' DIMENSION"}
Dim oPoint As Point2d
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(1, 6)
' Create the custom table
Dim oCustomTable As CustomTable
oCustomTable = oSheet.CustomTables.Add("IMB WELDING", oPoint, 4, 24, oTitles)
ekinsb
Here's a modified version of the sample from the API Help.  I think the problem you ran into running it is the difference in arrays between VBA and VB.Net.  I've modified this version so that it will be compatible with both and I've changed it so it outputs the table in your example, with the exception that the custom table doesn't support merging a column so they are still individual cells.
Public Sub CreateCustomTable()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim columnCount As Integer
    Dim rowCount As Integer
    columnCount = 4
    rowCount = 6
    ' Set the column titles
    Dim titles() As String
    ReDim titles(columnCount - 1)
    titles(0) = "SPIDER"
    titles(1) = "IMB"
    titles(2) = "PROCEDURE"
    titles(3) = "'A' DIMENSION"
    ' Set the contents of the custom table (contents are set row-wise)
    Dim contents() As String
    ReDim contents(columnCount * rowCount - 1)
    Dim row As Integer
    row = 0
    contents(4 * row) = "F25"
    contents(4 * row + 1) = "S-10090-2"
    contents(4 * row + 2) = "S15020-A"
    contents(4 * row + 3) = "33.25 [844.5]"
    row = row + 1
    contents(4 * row) = "F26"
    row = row + 1
    contents(4 * row) = "F27"
    row = row + 1
    contents(4 * row) = "F28"
    row = row + 1
    contents(4 * row) = "F29"
    row = row + 1
    contents(4 * row) = "F30"
    ' Set the column widths (defaults to the column title width if not specified)
    Dim columnWidths() As Double
    ReDim columnWidths(columnCount - 1)
    columnWidths(0) = 2.5
    columnWidths(1) = 3
    columnWidths(2) = 3
    columnWidths(3) = 3.5
    Set oCustomTable = oSheet.CustomTables.Add( _
                    "IMB WELDING", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
                    columnCount, rowCount, titles, contents, columnWidths)
End Sub
Brian Ekins
Mod the Machine blog
S7RM7RPR
Fantastic thank you so much.
The only modification I'm going to make is to loop it so I can vary my items but I think I can handle that part. I'll post the final code
S7RM7RPR
SyntaxEditor Code Snippet
Dim oSheet As Sheet
Dim IMB As String = Left(Parameter("IMB.ipt.IMB"),7)
SPIDER_QTY = Parameter("BOT SPIDERS.iam.SPIDER_QTY")
BCD = Parameter("BOT SPIDERS.iam.BCD")
NOTCH = Parameter("IMB.ipt.NOTCH") ' 1 OR 0
' logic start
columnCount = 4
rowCount = 0
For J = 25 To (SPIDER_QTY+24)
    If Parameter("SPIDER" & J & ".ipt.MTG") = True Then
        rowCount = rowCount + 1
Next
titles(1) = "IMB"
ReDim contents(columnCount *rowCount-1)
Dim row As Integer
Dim PROCEDURE As String
row = 0
        If IMB = "S-10090" Then
            PROCEDURE = "S-15020-"
        ElseIf IMB = "S-10040" Then
            PROCEDURE = "S-15021-"
        ElseIf IMB = "S-10130" Or IMB = "S-10131" Then
            PROCEDURE = "S-15022-"
        Else
            MsgBox("IMB ERROR")
        If Parameter("WELD_BEFORE") = True Then
            PROCEDURE = PROCEDURE & "WB"
        ElseIf Parameter("WELD_AFTER") = True Then
            PROCEDURE = PROCEDURE & "WA"
        If NOTCH = 1 Then
            PROCEDURE = PROCEDURE & "N"
        AdimIN = BCD / 2
        AdimMM = AdimIN * 25.4
        contents(4 * row) = "F" & J
        contents(4 * row + 1) = Parameter("IMB.ipt.IMB")
        contents(4 * row + 2) = PROCEDURE
        contents(4 * row + 3) = AdimIN & " [" & AdimMM & "]"
        row = row + 1
Next
columnWidths(0) = 1.5
columnWidths(1) = 2
columnWidths(2) = 2
columnWidths(3) = 3
oCustomTable = oSheet.CustomTables.Add("IMB WELDING", ThisApplication.TransientGeometry.CreatePoint2d(15, 15),columnCount, rowCount, titles, contents, columnWidths)
aronmatheus
There anyway create a macro to merge the cell "TOTAL MASS" erase the firsts lines in merge the setence "TOTAL MASS"?
There create a macro to calculate the total mass:
Sub testTotalMass()
Dim dwg As DrawingDocument
Set dwg = ThisApplication.ActiveDocument
Dim oview As DrawingView
Set oview = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Pick the assembly view")
On Error Resume Next
Dim asm As AssemblyDocument
Set asm = oview.ReferencedDocumentDescriptor.ReferencedDocument
If Err Then
MsgBox ("Not an assembly")
Exit Sub
Dim pl As PartsList
Set pl = dwg.ActiveSheet.PartsLists.Item(1)
Dim plr As PartsListRow
Dim found As Boolean
For Each plr In pl.PartsListRows
If plr.Item(3).Value = "TOTAL MASS" Then
found = True
Exit For
Next
Dim txn As Transaction
Set txn = ThisApplication.TransactionManager.StartTransaction(dwg, "Add total mass")
If found = False Then Set plr = pl.PartsListRows.Add(pl.PartsListRows.Count, False)
plr.Item(5).Value = Round(asm.ComponentDefinition.MassProperties.Mass, 3) & " kg"
txn.End
End Sub
