rotate view 1 su IDW
ch_giacomo
678 次查看
9 条回复
1 条消息(共 10 条)
ch_giacomo
Good morning everyone
I'm asking for help with a rule, but I'm stuck by my very little experience.
I got to this point:
' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    	oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    	oSheet = oDrawDoc.ActiveSheet
		 ' Select a drawing view.
    Dim oDrawingView As DrawingView = ActiveSheet.View("VISTA1").View
and what I would like is to rotate the already existing "view 1" into an IDW and set it to the ViewGoHome, hope I made myself clear.
I attach the result
0 个赞
679 次查看
9 条回复
回复 (9)
2 条消息(共 10 条)
Andrii_Humeniuk
Hi @ch_giacomo . This code changes the orientation of the camera:
Dim oSheet As Sheet
Dim oCamera As Camera = oSheet.DrawingViews.Item(1).Camera
oCamera.ViewOrientationType = 10766
oCamera.Apply()
 ViewOrientationTypeEnum List
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
0 个赞
3 条消息(共 10 条)
ch_giacomo
thanks for the help but I get an error or made a screen
0 个赞
4 条消息(共 10 条)
Andrii_Humeniuk
Added check by view name "VISTA1". What version of the Inventor are you using?
Dim oSheet As Sheet
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.Name = "VISTA1" Then
		oCamera = oView.Camera
		oCamera.ViewOrientationType = ViewOrientationTypeEnum.kSavedCameraViewOrientation
		oCamera.Apply()
	End If
Next
0 个赞
5 条消息(共 10 条)
ch_giacomo
2019 VERSION
WITH THE NAME "VISTA1" IT GIVES ME AN ERROR
OR TRIED TO ENTER "VIEW1"
IT DOESN'T RETURN AN ERROR BUT THE RULE DOESN'T ROTATE THE VIEW, PRACTICALLY NOTHING HAPPENS AS YOU ROLL THE RULE.
0 个赞
6 条消息(共 10 条)
ch_giacomo
Maybe it's the first part I wrote that could be wrong?
    Dim oSheet As Sheet
0 个赞
7 条消息(共 10 条)
Andrii_Humeniuk
Check out this Link . I changed line 10, maybe that will help.
Dim oSheet As Sheet
		oCamera.ApplyWithoutTransition
	End If
Next
0 个赞
8 条消息(共 10 条)
ch_giacomo
Thank you.
maybe I haven't been able to explain myself well.
I have many IDWs that have only one view "View1" and it is set differently between the various IDWs.. what I was looking for is by launching the rule that this view would be rotated as set in the "HOMEVIEWCUBE"
The link talks about a rule that changes the ViewCube... instead I'm talking about the view in the layout
0 个赞
9 条消息(共 10 条)
ch_giacomo
I found this rule that almost does the desired result... maybe this is an excellent starting point to modify it so that the view rotates as hoped:
oView = ActiveSheet.View("VIEW2").View
Dim oDDoc As DrawingDocument = oView.Parent.Parent
oSS = oDDoc.SelectSet
oSS.Clear
oSS.Select(oView)
oCD = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingViewRotateCtxCmd")
oSS.Select(oView)
oCD.Execute2(False)
AppActivate(ThisApplication.Caption)
System.Windows.Forms.SendKeys.SendWait("{DOWN}^A90{TAB}{UP}{ENTER}")
0 个赞
10 条消息(共 10 条)
ch_giacomo
0 个赞
