Hello everyone.
I use rule in ilogic to Change dimension in assembly mode, but errors. The code is following:
For example: If AEL = "level 1" then parameter "L1" in "B" part = some value. But it doesn't work
If AEL1 = "Level 1 - Minium" Then Parameter("A.Ext.580.930.27:1", "L1") = -115 ElseIf AEL1 = "Level 2" Then Parameter("A.Ext.580.930.27:1", "L1") = -135 ElseIf AEL1 = "Level 3" Then Parameter("A.Ext.580.930.27:1", "L1") = -154 ElseIf AEL1 = "Level 4" Then Parameter("A.Ext.580.930.27:1", "L1") = -174 ElseIf AEL1 = "Level 5" Then Parameter("A.Ext.580.930.27:1", "L1") = -193 ElseIf AEL1 = "Level 6 - Maximum" Then Parameter("A.Ext.580.930.27:1", "L1") = -213 End If
