My First Plug-in Lesson 1 Code Error
amarinXG8V6
amarinXG8V6
Folks,
Looking for some help with the below screen shot. When I try to go through Lesson 1 step by step, I'm getting this error when I'm trying to build the code. I can remove the DocumentTypeEnum signature but I have a feeling that's not what I'm supposed to do. The lesson doesn't mention modifying this portion of the code. I was on step 6 of Lesson 1. Excited to learn how to work within the VB.NET framework using Visual Studio 2022 but feeling a bit deflated after running into issues so early on. Help a wanna-be-nerd out!
Lesson 1: The Basic Plug-in – Autodesk Inventor
A.Acheson
Hi @amarinXG8V6
If I was betting that argument shouldn't be in the button click. The image in your link for button 1 doesn't have it and passing in a type argument doesn't seem right to me. I could be wrong as well as I haven't gone that far with events other than working with known working samples.
Regards
Alan
amarinXG8V6
@A.Acheson ,
I saw that also after posting to the forum. I did end up removing the type argument for Button_1 and everything worked fine. Thank you for responding and confirming!
Cheers,
Alex
