How to Change dimension in assembly mode, the detail size of each part changes accordingly? Use ilogic
htthanh_dzk
htthanh_dzk
Hello everyone.
I use rule in ilogic to Change dimension in assembly mode, but errors. The code is following:
For example: If AEL = "level 1" then parameter "L1" in "B" part = some value. But it doesn't work
If AEL1 = "Level 1 - Minium" Then
Parameter("A.Ext.580.930.27:1", "L1") = -115
ElseIf AEL1 = "Level 2" Then
Parameter("A.Ext.580.930.27:1", "L1") = -135
ElseIf AEL1 = "Level 3" Then
Parameter("A.Ext.580.930.27:1", "L1") = -154
ElseIf AEL1 = "Level 4" Then
Parameter("A.Ext.580.930.27:1", "L1") = -174
ElseIf AEL1 = "Level 5" Then
Parameter("A.Ext.580.930.27:1", "L1") = -193
ElseIf AEL1 = "Level 6 - Maximum" Then
Parameter("A.Ext.580.930.27:1", "L1") = -213
End If
A.Acheson
Hi @htthanh_dzk
Can you share the more info tab of the error message? And also an image of the assembly pointing to the parts being changed.
Regards
Alan
htthanh_dzk
The issue solved. Thanks All.
