Adding value to part from withing the drawing does not work
arkadiusz.budkowski
arkadiusz.budkowski
Does anyone know why this is not working?
Sub Main()
	Dim oDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oPartOnSheet As Inventor.PartDocument = oSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
	Dim userParams As Inventor.UserParameters = oPartOnSheet.ComponentDefinition.Parameters.UserParameters
	param = userParams.AddByValue("Uwaga_8", "", UnitsTypeEnum.kTextUnits)
	param.IsKey = True
End Sub
A.Acheson
Hi @arkadiusz.budkowski
What inventor version are you using? Can you post the "more info" or "więcej informacji"
text of the error message? Also which line does it fail on? Adding the parameter or before or after? Place into the code a message box and step through the code untill you no longer see the message box but get the error message.
Regards
Alan
Andrii_Humeniuk
Hi @arkadiusz.budkowski . Your code works fine for me, but I added one check, I could be wrong, but it seems you are trying to create a parameter for components that cannot be modifiable.
Sub Main()
	If oPartOnSheet.IsModifiable Then
		Dim param as UserParameter = userParams.AddByValue("Uwaga_8", "", UnitsTypeEnum.kTextUnits)
		param.IsKey = True
	Else
		MessageBox.Show("Your component does not modifiable.", "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
arkadiusz.budkowski
I just now had time to come back to the problem and I don't know why but it started to work. Maybe it was an inventor random problem. I will use the updated code, seems more secure, thanks
