Dimension Text is rotated by 90° when rearranging dimension with iLogic rule
Darrell.johnson
Darrell.johnson
Hello, I created an iLogic Rule to arrange the dimensions in a drawing document automatically.
Private Sub ReArrangeDrawingDimensions(oSheet As Inventor.Sheet, drawingView As Inventor.DrawingView, dimensionName As String, Optional xCoord As Double = 0, Optional yCoord As Double = 0)
	Dim oGeneralDimensions As GeneralDimensions
	oGeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
	Dim xCoordComp, yCoordComp As Double
	Dim oWidthDim, oHeightDim, oDepthDim As LinearGeneralDimension
	Dim oCompDim As LinearGeneralDimension
	Dim newPosComp As Point2d
	For Each oGeneralDimension As GeneralDimension In oGeneralDimensions
		If oGeneralDimension.AttributeSets.Count >0 Then
			If oGeneralDimension.AttributeSets.Item(1).Name = dimensionName Then
				oCompDim = oGeneralDimension
	Next
	If xCoord = 0 Then
		xCoordComp = oCompDim.Text.Origin.X
	Else
		xCoordComp = xCoord
	If yCoord = 0 Then
		yCoordComp = oCompDim.Text.Origin.Y
	Else
		yCoordComp = yCoord
	newPosComp = ThisApplication.TransientGeometry.CreatePoint2d(xCoordComp, yCoordComp)
	oCompDim.Text.Origin = newPosComp
End Sub
For most of the dimensions this rule works just fine but one dimension is giving me trouble.
The Dimension Text is rotated by 90 ° and I can't figure out why.
The only thing different from the other dimensions is that the DimensionLine.Direction.Y Property of the dimension is -1 instead of 1, but this property is read-only.
Darrell.johnson
I just realized that this dimension is the only one placed on circular geometry.
By putting a sketch on the hole and placing lines on the circular geometry, it works as intended.
Darrell.johnson
The above mentioned method of placing lines on circular geometry, doesn't work either, for some weird reason it just worked one time.
vvvxxvvv333
can you share the file where that rule works? There is an error on my screen
Darrell.johnson
Sub Main
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDoc.Sheets(1)
	Dim dimensionName As String = "test"
	If oSheet.DrawingDimensions(1).AttributeSets.Count = 0 Then
		oSheet.DrawingDimensions(1).AttributeSets.Add(dimensionName)
	Dim oView As DrawingView = oSheet.DrawingViews(1)
	Dim xCoord As Double = oView.Left + oView.Width + 1
	Dim yCoord As Double = oView.Top - oView.Height - 1
	ReArrangeDrawingDimensions(oSheet, oView, dimensionName, xCoord, yCoord)
End Sub
	Next
	If xCoord = 0 Then
	Else
		xCoordComp = xCoord
	If yCoord = 0 Then
	Else
		yCoordComp = yCoord
End Sub
Darrell.johnson
@vvvxxvvv333: Here is the  file where the rule works. Which kind of error are you getting?
Darrell.johnson
I found a solution. If you center the dimension text before rearranging it, the text orientation doesn't change an is displayed as intented.
Private Sub CenterDrawingDimensions(oSheet As Inventor.Sheet, dimensionName As String)
	For Each oDim As DrawingDimension In oSheet.DrawingDimensions
		If oDim.AttributeSets.Count >= 1 Then
			If oDim.AttributeSets(1).Name = dimensionName Then
				oDim.CenterText
	Next
End Sub
