Insert an instance properties when placing a component from Content Center
EduLourenco
EduLourenco
Hello all,
I require an ilogic rule that inserts an instance property when i place a component from content center.
I guess the structure (if possible) would be something like this
code that opens the Content Center library
after picking and placing the component, runs the following code
create instance properties column "TAG" and inserts the writable field
in the end the ideia is to get a form like this
thanks in advance
A.Acheson
Hi @EduLourenco
The instance portion of the code would be easy enough to create. Here is the help file for this.
iProperties.InstanceValue("PartX:1", "Side") = "Left"
Dim partX1Side = iProperties.InstanceValue("PartX:1", "Side")
 And here is a forum example.
The request to browse for a content center part is an extremely difficult one.It would involve entirely replicating the existing content center folder dialog. A better solution would be to just place the part manually and then create the instance.
Regards
Alan
