Robot movement
Robot movement
GeorgK
Advisor Advisor
Message 1 of 10
Robot movement
GeorgK
Hello together,
I found this post:
https://forums.autodesk.com/t5/inventor-customization/robot-path-generation-from-3d-cad/m-p/8289075
which is very interesting. Does anyone have experience with controlling robots in Autodesk Inventor? Or has someone already programmed something in this direction? What could be the ideal process? Create points that the robot should approach and place a spline through the points and then drive it off.
I found this attempts:
http://www2.dem.uc.pt/pedro.neto/PUB/IC/IC_11.pdf
http://www2.dem.uc.pt/pedro.neto/PUB/IC/IC_3.pdf
https://estudogeral.sib.uc.pt/bitstream/10316/27383/1/Direct%20off-line%20robot%20programming%20via%...
Thank you
Georg
Replies (9)
Message 2 of 10
AlexFielder
Hi @GeorgK,
This appears to be the profile of the researcher involved in the papers you linked to:
https://www.researchgate.net/profile/Pedro_Neto2
I've had a quick search around github and he doesn't seem to have shared any code relating to the topic (that I can find so far) but then the video in the other topic you linked to is ~9 years old.
Message 3 of 10
GeorgK
Hello @AlexFielder,
I didn't find any code from those projects. Are you interested to develop some tools?
Georg
Message 4 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Hoping that suggestions in below blog link may be helpful.
http://adndevblog.typepad.com/manufacturing/2012/06/get-equi-distant-points-on-curve-using-parameter...
In this blog, a 2D spline is used to get points at equidistance.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 10
GeorgK
@chandra.shekar.g
Is there a function for 3dsplines as well?
Message 7 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Unfortunately, points at equidistance in 3D spline may not achievable one.
I found a alternative approach to calculate points along 3D spline. This approach is triggered by below screencast video link.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/screencast/Main/Details/...
In this approach, a workpoint will be created at start point of 3D spline. Then, work point is pattern through RectanglarPatternFeature at desired numbers (In this example, 50 is number) as shown below.
 Sub Calculate_Points()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oPt As WorkPoint
    Dim cnt As Integer
    cnt = oDef.WorkPoints.Count
    Dim i As Integer
    For i = 2 To cnt 'As first workpoint would be origin of Document, from 2nd point is considered.
        Set oPt = oDef.WorkPoints.Item(i)
        Debug.Print ("X : " & oPt.Point.X & " Y : " & oPt.Point.Y & " Z : " & oPt.Point.Z)
    Next
 End Sub
Using VBA code, points along 3D spline can be evaluated. Result for attached part(3D Spline_part.ipt) is as below.
X : -2.46898259348225 Y : -1.40508689238043 Z : 0
X : -2.71050315324226 Y : -1.19618511793428 Z : 0.158557339645586
X : -2.94644675335194 Y : -0.975929846994496 Z : 0.310163146331132
X : -3.17392306599431 Y : -0.741029563399514 Z : 0.452245501532895
X : -3.38767887017583 Y : -0.486270063951254 Z : 0.580398620041887
X : -3.57650506158435 Y : -0.203160125884033 Z : 0.685896478424769
X : -3.71152825164767 Y : 0.119366086561862 Z : 0.74840442076525
X : -3.72270096159725 Y : 0.47017234345809 Z : 0.725473894196636
X : -3.56550586596302 Y : 0.761850601996243 Z : 0.605203256622316
X : -3.31626580647378 Y : 0.959609873232407 Z : 0.446556299186176
X : -3.03066689632245 Y : 1.09601841698217 Z : 0.283033052878371
X : -2.72709280008959 Y : 1.19459504535069 Z : 0.12429834151262
X : -2.41213654829953 Y : 1.26773749409372 Z : -0.026114161886064
X : -2.08881016979362 Y : 1.32235286918349 Z : -0.166083225166605
X : -1.75851265397028 Y : 1.36265780204705 Z : -0.29385260221132
X : -1.42192442726761 Y : 1.39136656261154 Z : -0.407533804189369
X : -1.0795059513938 Y : 1.41027768644489 Z : -0.504805210151995
X : -0.7317441584476 Y : 1.42059620920782 Z : -0.582706127256179
X : -0.379378389313913 Y : 1.42311052987894 Z : -0.637420016254555
X : -2.37621625549078E-02 Y : 1.4182919848087 Z : -0.66403601938784
X : 0.332187328054961 Y : 1.40637688064561 Z : -0.656421602013299
X : 0.684703345605513 Y : 1.38736963799945 Z : -0.607352670438247
X : 1.02627509628939 Y : 1.36117888105942 Z : -0.509546355019176
X : 1.34685019987767 Y : 1.32765773391351 Z : -0.358115067101314
X : 1.6361187650665 Y : 1.28647637537227 Z : -0.153431258415742
X : 1.88541615199245 Y : 1.23710192643129 Z : 9.53280399010263E-02
X : 2.09612020917794 Y : 1.17705773811351 Z : 0.37632131899589
X : 2.27610133194124 Y : 1.10081750484712 Z : 0.674410254835628
X : 2.44242741453148 Y : 0.995375094723439 Z : 0.97141720432737
X : 2.62195803290582 Y : 0.832276951837899 Z : 1.23070140006612
X : 2.83915708748131 Y : 0.579155258830164 Z : 1.32915824372238
X : 3.03621259386137 Y : 0.325145357235721 Z : 1.18497892506639
X : 3.18945916977914 Y : 0.12326921999316 Z : 0.933394249771263
X : 3.31262582500243 Y : -3.95504397012549E-02 Z : 0.642847511898662
X : 3.4147085351109 Y : -0.175145207189773 Z : 0.330061388726886
X : 3.49835536126774 Y : -0.287909358819233 Z : 1.81472224989898E-03
X : 3.56312039385875 Y : -0.378531894215993 Z : -0.336845200000238
X : 3.60704708302688 Y : -0.446145673891437 Z : -0.683941953365482
X : 3.6258372641962 Y : -0.48748969281402 Z : -1.03753711156675
X : 3.6120221057882 Y : -0.496212743055283 Z : -1.39351869335621
X : 3.55366094164134 Y : -0.461837617967627 Z : -1.74415467383304
X : 3.43626599016305 Y : -0.371225499830548 Z : -2.06660166837566
X : 3.25145928068042 Y : -0.216874171729289 Z : -2.32714905188019
X : 3.01441426386791 Y : -1.27330027740926E-02 Z : -2.49522097465731
X : 2.7528944630157 Y : 0.215329383311388 Z : -2.57391668858989
X : 2.48502903555953 Y : 0.450108931456778 Z : -2.58552105070323
X : 2.21837392400982 Y : 0.684246521821899 Z : -2.55018730801869
X : 1.95584119578995 Y : 0.914827259367977 Z : -2.48173851663527
X : 1.69702536728794 Y : 1.14203403106343 Z : -2.38874732893089
X : 1.44294865358406 Y : 1.36488564150061 Z : -2.27743729393491
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 10
GeorgK
Hello @chandra.shekar.g,
thank you very much. Is there no solution to calculate the points? It must be possible to interpolate the spline.
Message 9 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
I will let you know if I found any solution to interpolate the spline.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 10
GeorgK
@chandra.shekar.g
Could you find a solution for the problem?
