BOM row static quantity programatically...?
oransen
Message 1 of 15
oransen
I can set the quantity in a BOM to be static by hand, and insert the quantity I want to.
And once it is set to static I can change the quantity programatically:
            CComBSTR bstrNewTotalQuantity = L"666,666" ;
            ThisBomRow->put_TotalQuantity(bstrNewTotalQuantity);
However I can't find out how to set the BOM quantity item to static from within my program. Both my tests and the help say that put_TotalQuantityOverridden can only be used to set things to FALSE.
How can I do with the API what I do by hand, i.e. set TotalQuantityOverridden to TRUE?
Or have I missed something?
Replies (14)
Message 2 of 15
bradeneuropeArthur
Public Sub BOMSTATIC()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As BOM
Set c = b.ComponentDefinition.BOM
MsgBox c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantity
c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantity = 2 "OR YOUR qty...."
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
oransen
This works if the TotalQuantity is already a static. But if it is calculated (at least as far as I can tell) it remains calculated.
My question was how to change from calculated to static programatically.
I think...
Message 4 of 15
bradeneuropeArthur
c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantityOverridden = False
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 15
oransen
But I want it to be True. The docs say you can set it to False, but not to True. And my experiments confirm that.
If the item is already True then I can change the TotalQuantity.
Message 6 of 15
oransen
To be more specific:
            hRes = ThisBomRow->put_TotalQuantityOverridden(VARIANT_TRUE);
            if (FAILED(hRes)) {
                gLogger.Printf(ekLogMsg, L"    Could not set overridden", pDefinitionsEnum->Count);
If TotalQuantityOverridden is already true I don't get the message "Could not set overridden".
It TotalQuantityOverridden is false then I get the message "Could not set overridden"
And this confirms what the API help says.
Message 7 of 15
bradeneuropeArthur
I can set it to true!
What version of Inventor are you using?
c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantityOverridden = True
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 15
oransen
Inventor 2017
Message 9 of 15
bradeneuropeArthur
I don't understand the question anymore then!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 15
oransen
When you do this...
...could you check that it was originally false and that it really goes to True?
Which version of Inventor are you using?
Message 11 of 15
bradeneuropeArthur
I will try that.
Inventor 2018
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 15
bradeneuropeArthur
Sorry but you are right.
With this it is possible what you need I think.
I found out what you mean.
but you need to add the value first to initialize
Dim c As BOM
Dim OriginalSet As Boolean
OriginalSet = c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantityOverridden
MsgBox OriginalSet
c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantity = c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantity
Dim NewSetTrue As Boolean
NewSetTrue = c.BOMViews.Item(1).BOMRows.Item(1).TotalQuantityOverridden
MsgBox OriginalSet & " VS " & NewSetTrue
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 15
oransen
Thanks @bradeneuropeArthur for testing all this. I'm not sure what the equivalent in C++ is though. I'll wait till the authorities reply, maybe there's a simple solution we have missed...
Message 14 of 15
bradeneuropeArthur
I am curious too.
I think Autodesk does the same as the last code, by setting the value first to his initial value.
Don't you think?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 15
oransen
@bradeneuropeArthur  wascompletely right. Strangely enough you have to set the quantity before you set Overriden
            // Do this before you do put_TotalQuantityOverridden
            CComBSTR bstrNewTotalQuantity = L"77" ;
Now all I need to do is work out how to change from "Each" to...
Odd eh?
