iLogic rule to suppress all document rules
Lewis.Young
Message 1 of 11
Lewis.Young
Hi All,
Does anybody have a working iLogic code that when ran externally, will iterate through every internal rule in a document and suppress them?
I know you can do this by explicitly naming each rule, but in this case that won't suffice
After looking through the API object model im starting to think this isn't possible...
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Replies (10)
Message 2 of 11
philip1009
What's the method for suppressing iLogic rules by name?
Message 3 of 11
Lewis.Young
Hi Philip,
The rule i use for suppressing by name is as follows:
SyntaxEditor Code Snippet
AutoRulesList = New String() {"Rule1","Rule2","Rule3"}
For Each rulename In AutoRulesList
    iLogicVb.Automation.GetRule(ThisDoc.Document, rulename).IsActive = False
Next rulename
On the first line you have to specify the rules, in this case rules 1, 2 and 3.
I'm just trying to find a way where i don't have to specify the names.
Lewis Young
Vault Basic 2017
3ds Max 2018
Message 4 of 11
philip1009
I found a site that deletes all rules in an assembly and all referenced parts and assemblies: https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020531-Inventor-2015-iLogic-Delete-All-iLogi...
I whittled down the code for getting the list of rules in a collection to peruse, you'd just have to apply your suppress code instead of the delete code:
Sub Main()
Auto = iLogicVb.Automation
Dim iLogicAuto As Object = Auto
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim RuleColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
'This command peruses rules for Top Assy
RuleColl = BuildRuleColl(oDoc, RuleColl, iLogicAuto)
'This Loop peruses rules for All Referenced Parts and Assys
For Each oSubDoc As Document In oDoc.AllReferencedDocuments
	RuleColl.Clear
	RuleColl = BuildRuleColl(oSubDoc, RuleColl, iLogicAuto)
Next
End Sub
Function BuildRuleColl(ByVal Doc As Document, ByRef RuleColl As ObjectCollection, ByVal iLogicAuto As Object) As ObjectCollection
	Dim ruleName As String
	Dim rules As Object = iLogicAuto.rules(Doc)
	If Not (rules Is Nothing) Then
		For Each rule In rules
			RuleColl.Add(rule)
		Next
	Return RuleColl
End Function
Hopefully this works out the way you want it.  Make sure to test this on some dummy files or copies of the original files so you don't do major damage.
Message 5 of 11
lmc.engineering
Hi @Lewis.Young
Try this
Version:1.0 StartHTML:00000145 EndHTML:00004412 StartFragment:00000294 EndFragment:00004380 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
Sub Main()
    Dim iLogic As Object
    iLogic = GetiLogicAddin(ThisApplication)
    If (iLogic Is Nothing) Then Exit Sub
    Dim doc As Document
    doc = ThisApplication.ActiveDocument
    iLogicAutomation = iLogic.Automation
	Dim ruleCol As System.Collections.IEnumerable = iLogicAutomation.Rules(doc)
	For Each iLogRule As iLogicRule In ruleCol
	'MessageBox.Show(iLogRule.Name, "Title")
	iLogRule.IsActive = False
	Next
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
    addIns = oApplication.ApplicationAddIns
    Dim addIn As ApplicationAddIn
    addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
    If (addIn Is Nothing) Then Exit Function
    addIn.Activate
    Return addIn
    Exit Function
    NotFound:
End Function
Message 6 of 11
Lewis.Young
Nice one mate, works perfectly!
Lewis Young
Vault Basic 2017
3ds Max 2018
Message 7 of 11
gregor.leban
is there a rule, to also suppress all sub-assembly rules?
Message 8 of 11
lmc.engineering
Hi @gregor.leban
I've moved the main method of the code to it's own function and am calling it from a loop through all referenced components in the assembly; this way we can call it on the main assembly and it's components.
Sub Main()
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
	'Suppress all main assembly rules
	Call SuppressRules(oAsmDoc, iLogicAutomation)
	'Suppress all component rules
	For Each refDoc As Document In oAsmDoc.AllReferencedDocuments
		Call SuppressRules(refDoc,iLogicAutomation)
	Next
End Sub
Private Function SuppressRules(Doc As Document,iLogicAutomation As Object)
	Dim ruleCol As System.Collections.IEnumerable = iLogicAutomation.Rules(Doc)
		Next
Return Nothing
End Function
Private Function GetiLogicAddin(oApplication As Inventor.Application) As Object
    addIn.Activate
    Return addIn
End Function
Message 9 of 11
gregor.leban
hi,
this code suppress assembly, but not sub-assembly.
And then I get an error:
Object reference not set to an instance of an object.
detail info of error:
System.NullReferenceException: Object reference not set to an instance of an object.
   at ThisRule.SuppressRules(Document Doc, Object iLogicAutomation)
   at ThisRule.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 10 of 11
lmc.engineering
Sorry, that's my bad. I believe this is because some of your parts don't have rules in, and as such throws an error when attempting to suppress something that isn't there. The following should fix the issue.
Sub Main()
	Next
End Sub
	If Not ruleCol Is Nothing Then
		Next
Return Nothing
End Function
    addIn.Activate
    Return addIn
End Function
Message 11 of 11
gregor.leban
jeeej, it works!
Thank you!
