vba to copy ilogic document Forms
cshunt
cshunt
I am trying to have a bit of code to update old drawings with rules and forms we have written into new templates. ideally these should be global forms but that hasn't happened at our office yet.
The rule part runs and works as expected. I cannot find any data on copying the forms. I can manually do this with mouse clicks so I expect it is written into the api but that is not accessible with vba. I made the assumption that it would be called forms but this does not seem to work.
Any help with accessing the form aspect of ilogic would be appreciated. My attempt is shown in the end of code below.
Thanks.
Sub ilogicCopyDeleteRules()
Dim oApp As Application: Set oApp = Inventor.ThisApplication
Dim oNewDoc As DrawingDocument
Set oNewDoc = oApp.ActiveDocument
Dim iLogicAuto As Object: Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
Dim oSourceFile As String
'oSourceFile = "testsourcefile.idw"
If oSourceFile = "" Then
Dim oOpenDialog As FileDialog
Call ThisApplication.CreateFileDialog(oOpenDialog)
    With oOpenDialog
        .Filter = "Drawing(*.idw)|*.idw"
        .DialogTitle = "Pick ilogic Source Drawing"
        .OptionsEnabled = False
        .SuppressResolutionWarnings = True
        .ShowQuickLaunch = True
        '.ShowSave
        .ShowOpen
        If .fileName = "" Then
            Exit Sub
        Else
            oSourceFile = .fileName
    End With
    Set oOpenDialog = Nothing
  Dim oDoc As DrawingDocument
  'Set oDoc = oApp.Documents.Open(oSourceFile, True)
  Set oDoc = oApp.Documents.Open(oSourceFile, False) 'don't show document
Dim SourceParameters As UserParameters, SourceParameter As UserParameter
Set SourceParameters = oDoc.Parameters.UserParameters
Dim TargetParameters As UserParameters, TargetParameter As UserParameter
Set TargetParameters = oNewDoc.Parameters.UserParameters
Dim FoundParameter As Boolean: FoundParameter = False
Dim oParameter As Parameter
If MsgBox("Copy all parameters? you will need the names if fx params are blank" & vbCrLf & "Values will be from source document", vbYesNo) = vbYes Then
For Each SourceParameter In SourceParameters
            For Each TargetParameter In TargetParameters
                        If TargetParameter.Name = SourceParameter.Name Then
                        FoundParameter = True
                        Exit For
            Next
        If FoundParameter <> True Then
        Set oParameter = TargetParameters.AddByValue(SourceParameter.Name, SourceParameter.Value, SourceParameter.Units)
        If Not SourceParameter.ExpressionList Is Nothing Then If SourceParameter.ExpressionList.count > 0 Then Call oParameter.ExpressionList.SetExpressionList(SourceParameter.ExpressionList.GetExpressionList())
'not sure if we should clear out parameters or just copy them.... for now I will just copy
Next
Dim RuleColl As ObjectCollection: Set RuleColl = ThisApplication.TransientObjects.CreateObjectCollection
If MsgBox("Delete all iLogic rules in ALL components in this assembly?", vbYesNo) = vbNo Then Exit Sub
'delete all ilogic rules in target document
    Call iLogicAuto.DeleteAllRulesInDocument(oNewDoc)
' Build collection of rules
Dim ruleName As String, rules As Object, rule As Object, ruleText As String
Dim NewRule
Set rules = iLogicAuto.rules(oDoc)
If Not (rules Is Nothing) Then
    For Each rule In rules
        'Call iLogicAuto.DeleteRule(oDoc, rule.Name)
        'if you add the rule, then add the text to the rule, they do not run
        ruleName = rule.Name
        ruleText = rule.Text
        Set NewRule = iLogicAuto.AddRule(oNewDoc, rule.Name, "") 'rule.Text)
        NewRule.Text = rule.Text 'ilogic code
        'Call RuleColl.Add(rule)
    Next
'Dim FormName As String, Forms As Object, Form As Object, FormText As String
'Dim NewForm
'Set Forms = iLogicAuto.ilogicFormsAndRulsEditor(oDoc)
'If Not (Forms Is Nothing) Then
'    For Each Form In Forms
'        'Call iLogicAuto.DeleteRule(oDoc, rule.Name)
'        'if you add the rule, then add the text to the rule, they do not run
'        FormName = Form.Name
'        FormText = Form.Text
'        Set NewForm = iLogicAuto.AddForm(oNewDoc, Form.Name, "") 'rule.Text)
'        NewForm.Text = Form.Text 'ilogic code
'        'Call RuleColl.Add(rule)
'    Next
'End If
oDoc.Close
End Sub
cshunt
Fixed a mistake in the posted code. No luck on copying forms yet.
oSourceFile = ""
    With oOpenDialog
        '.ShowSave
        .ShowOpen
            Exit Sub
        Else
    End With
                        Exit For
            Next
Next
Dim NewRule
    Next
'Dim NewForm
'    Next
'End If
oDoc.Close
End Sub
