Create Ilogic Help
Create Ilogic Help
cyndel.pigeon
Create Ilogic Help
cyndel.pigeon
Hey!
How can I say :
Example:
(In an assembly)
If ''ComponentName'' is in the assembly Then
iProperties.Value("ComponentName", "Custom", "Vqty") = InputBox("ENTER QUANTITY FOR CABLE CLIPS GALVANIZED", "Vqty", "")
OR
If ''CABLE CLIPS GALVANIZED:1'' is not in the assembly Then do nothing and proceed with the next line...
So I would like to say...if ''the component'' is in the assembly then modify one custom proprety by an input box...and if the component is not in the assembly then execute the next line in the rule...instead of doing nothing...I got an error message saying that the component cannot be found...
(Sorry if it's not clear...I'm not familiar with Ilogic)
SyntaxEditor Code Snippet
If Component.IsActive("CABLE CLIPS ALUMINIUM:1") = True Then
iProperties.Value("CABLE CLIPS ALUMINIUM:1", "Custom", "Vqty") = InputBox("ENTER QUANTITY FOR CABLE CLIPS GALVANIZED", "Vqty", "")
If Component.IsActive("CABLE CLIPS ALUMINIUM:1") = False Then
If Component.IsActive("CABLE CLIPS GALVANIZED:1") = True Then
iProperties.Value("CABLE CLIPS GALVANIZED", "Custom", "Vqty") = InputBox("ENTER QUANTITY FOR CABLE CLIPS", "Vqty", "")
'ETC ...
Thanks!
philip1009
That code is asking if a component with that name in the assembly is Active or not, which is meant to control suppression, not check if it exists.
Here's a sample to check if something exists in an Assembly:
For Each oOcc As ComponentOccurrence In ThisDoc.Document.ComponentDefinition.Occurrences
	If oOcc.Name = "ComponentName" Then
		iProperties.Value(oOcc.Name, "Custom", "Vqty") = InputBox("ENTER QUANTITY FOR CABLE CLIPS GALVANIZED", "Vqty", )
Next
This is a For Each loop that checks through the collection of Occurrences (Parts and Assemblies) in the assembly document this rule is run from.  For Each Occurrence in the collection of Occurrences it will run what ever code between the For Each line and the line stating Next.
