Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i need to change revision table collumn width via vba anybody have this code?
by
karthikeyan
by
karthikeyan
Hope this code will full fill your requirement.
Sub Change_Revision_table_width()
Dim oDoc As Document
Dim oSheet As Sheet
Dim oRevisionTables As RevisionTable
Dim oRevisionTableColumn As RevisionTableColumn
Dim oColumnName As String
Dim oWidth As Double
Set oDoc = ThisApplication.ActiveDocument
If oDoc.DocumentType = kDrawingDocumentObject Then
Set oSheet = oDoc.ActiveSheet
oSheet.Activate
For Each oRevisionTables In oSheet.RevisionTables
For Each oRevisionTableColumn In oRevisionTables.RevisionTableColumns
oColumnName = oRevisionTableColumn.Title
oWidth = InputBox("Enter the width of the Column Name : " + oColumnName + "", "Enter Column Width")
oRevisionTableColumn.Width = oWidth
Next
Next
Else
MsgBox "The Selected document is not a drawing document please select a drawing document and continue", vbOKOnly, "Edit Revision Table Column Width:"
Exit Sub
End If
End Sub
Please accept this as solution if it resolves your requirement
Thank for your help. Its working .I need some modification in this coding something like
If revTable.RevisionTableColumns.Item(colIndex).PropertyType = kRevisionTableCustomProperty And _
revTable.RevisionTableColumns.Item(colIndex).Title = "Rev. Date" Then
oWidth="5"
End If
I don't know how to include this. Plz help.
My table is constant every time it won't change. some adjustment has to be done in some collumns
Thank you,
karthikeyan M
Hi Karthik,
I've modified the code as you need. Hope this gonna solve your issue.
Sub Change_Revision_table_width() Dim oDoc As Document Dim oSheet As Sheet Dim oRevisionTables As RevisionTable Dim oRevisionTableColumn As RevisionTableColumn Dim oColumnName As String Dim oWidth As Double Set oDoc = ThisApplication.ActiveDocument If oDoc.DocumentType = kDrawingDocumentObject Then Set oSheet = oDoc.ActiveSheet oSheet.Activate For Each oRevisionTables In oSheet.RevisionTables For Each oRevisionTableColumn In oRevisionTables.RevisionTableColumns oColumnName = oRevisionTableColumn.Title if oColumnName = "Rev" then ' <--- You Can change the column name in here to what ever column you need oWidth = InputBox("Enter the width of the Column Name : " + oColumnName + "", "Enter Column Width") oRevisionTableColumn.Width = oWidth endif Next Next Else MsgBox "The Selected document is not a drawing document please select a drawing document and continue", vbOKOnly, "Edit Revision Table Column Width:" Exit Sub End If End Sub
If you find this going to help you please accept this as solution.
SK
Hey Guys,
this thread is not the newest one, I know, but I have a problem that is pretty much the same described here. I just can't seem to get the width of the RevisionTableColumns changed.
When I run exactly your code (just changing the name of the column), this is the error I get. Does anybody have an idea how to fix this? I'm using Inventor 2017.3 (Build 256).
Thanks in advance for your help!
Greetings
Thomas
Did you spell your column Right.
look also for characters (:_-:' etc ) and displayname and name etc.
Maybe the display-name of your column is different from you Column-name
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hi bradeneurope, thx for the reply.
If I see it right, the following part of the code prevents me from getting the name wrong:
If oColumnName = "REV." Then ' <--- You Can change the column name in here to what ever column you need oWidth = InputBox("Enter the width of the Column Name : " + oColumnName + "", "Enter Column Width") oRevisionTableColumn.Width = CDbl(oWidth) End If
Simply because if there is no Column with ColumnName "REV.", then I would never get the prompt for the Width. But I do get that prompt.
And by the way: I'm getting the same error as in my previous post, if I simply try to give one column the width of another column.
With testtable.RevisionTableColumns MsgBox .Item(4).Width .Item(1).Width = .Item(4).Width End With
This part returns an error and I just don't know why...
