Replace symbol from Template
autodeskpelinder
Message 1 of 16
autodeskpelinder
I need to change TitleBlock, Border and symbol and  in many drawings.
I don´t want to copy yhe symbol in to all  the drawings. I like to use a symbol from the templates, or symbol library.
It would be wonderful if it would be possible to change more then one symbol in the same rule.
I can change the TitleBlock and Border, but the rule don´t find the symbol.
What is the different of:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
and
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document?
This is my code (that only work if the symbol exist in the drawing):
ThisDrawing.ResourceFileName = "R:\Projekt\180 - ETK AB\180602 - Bodens Värmeverk - P18\3D-projekt\Inventor\Templates\Standard.idw"
ThisDrawing.KeepExtraResources = False
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
'Dim oDrawDoc = ThisApplication.ActiveDocument
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
Dim oCurrentNumber As Sheet
oCurrentNumber = oDoc.ActiveSheet
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets ' Iterate through the sheets, and delete the title blocks and symbols
oSheet.Activate
For Each oSymbol In oSheet.SketchedSymbols 'remove existing sketched symbols named Text Secondary steel
If oSymbol.Definition.Name = "General3" Or oSymbol.Definition.Name = "General Drawing1" _
Or oSymbol.Definition.Name = "General" Or oSymbol.Definition.Name = "General2" Then
oSymbol.Delete
Next
'============ Lägger in rätt symbol på rätt ställe
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document ' Set a reference to the drawing document. This assumes a drawing document is active.
'Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSketchedSymbolDef As SketchedSymbolDefinition _
= oDrawDoc.SketchedSymbolDefinitions.Item("General3")
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry 'create insertion point, coordinates - in cm !
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(83.6, 28) '(74, 52)
Dim oSketchedSymbol As SketchedSymbol _
= oSheet.SketchedSymbols.Add( _ ' Add an instance of the sketched symbol definition to the sheet.
oSketchedSymbolDef, _ ' Rotate angle = 0 radians,
oInsertionPoint, _ ' scale = 1 when adding
0, 1, Nothing) ' no prompt text
'============================================================== Put in the Symbol "General3" DOES NOT WORK !!
Dim oSketchedSymbolDef2 As SketchedSymbolDefinition _
Dim oTG2 As TransientGeometry = ThisApplication.TransientGeometry 'create insertion point, coordinates - in cm !
Dim oInsertionPoint2 As Point2d = oTG.CreatePoint2d(83.6, 28)
Dim oSketchedSymbol2 As SketchedSymbol _
Try
oSheet.TitleBlock.Delete
Catch 'catch error if no border found
End Try
ActiveSheet.TitleBlock = "Boden rithuvud2" 'Byter rithuvudet till Boden rithuvud 2 från templatesen.
Try
oSheet.Border.Delete
End Try
ActiveSheet.Border = "Boden2" 'set new border
Next
Try '============== Sparar ritningen som dwg. Med samma namn och på samma plats.
ThisDoc.Document.SaveAs(ThisDoc.Path & "\" & ThisDoc.FileName(False) & (".dwg") , True)
Catch
MessageBox.Show("Det gick tyvärr inte att spara filen som dwg." & vbLf & _
"Vill ni vara snäll och kontrollera att dwg-filen är stängd?", "Problem med dwg-filen")
End Try
Johan Sweden
Replies (15)
Message 2 of 16
MechMachineMan
FTFY -- proper nesting with readability.
Now, what isn't working? is it throwing an error?
Also, your code is currently trying to add general3 twice...
Dim oSheet As Sheet
	oSheet.Activate
			oSymbol.Delete
	Next
	Try
	End Try
	Try
	End Try
Next
Catch
End Try
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 16
autodeskpelinder
The problem is that it does not replace the symbol if the symbol is not in the drawing.
Sorry I had the same symbol twice. I tried to place 2 different symbols on the drawing, but I failed.
I get this error:
Error in rule: Change symbol, in document: 14361.idw
Felaktig parameter. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
See also the attached pictures.
Johan Sweden
Message 4 of 16
bradeneuropeArthur
you can use "Drawing Resource Transfer Wizard" found in:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk Inventor 20##\Tools
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 16
autodeskpelinder
Hi!
No. I have tried that. But I have 200 drawings and all of them is in different folders.
That program is not so good. I can only add more then one drawing at the same time if they are in the same folder.
For that reason it will take long time to fix them all.
Is it not possible to change the symbol as easy as I change the titleblock?
Thank you.
Johan Sweden
Message 6 of 16
bradeneuropeArthur
Yes.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 16
bradeneuropeArthur
Could you please upload the following:
With this code it will work:
Public Sub updateSymbols()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim temp As DrawingDocument
Set temp = a.Documents.Open("C:\Vault\Projects\Temp.dwg", False)' This needs to be your template drawing.
Dim sks As SketchedSymbolDefinition
Set sks = temp.SketchedSymbolDefinitions.Item(1)
'MsgBox (sks.Name)
For Each sks In temp.SketchedSymbolDefinitions
Call sks.CopyTo(b, True)
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 16
autodeskpelinder
Thank you for the quick reply. I will try it tomorrow.
But I don't think I can use "set".
When I have tried it before Inventor show an error that tells me that set-command is no longer in use.
Kind regards Johan
Johan Sweden
Message 9 of 16
bradeneuropeArthur
For i-ogic
Public Sub main()
  a = ThisApplication
'MsgBox (sks.Name)
Next
 End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 16
autodeskpelinder
Hi!
Thank you very much!
I could not put my rule in your rule, then I get an error:
Rule Compile Errors in Byta symbol, in 14363.idw
Error on Line 3 : Application är tvetydigt. Importerat från namnområdena eller typerna Inventor, System.Windows.Forms.
But if I run my rule from yours it works 🙂
But I can still only change one symbol at the time:
SyntaxEditor Code Snippet
Public Sub Main()
  a = ThisApplication
temp = a.Documents.Open("R:\Projekt\180 - ETK AB\180602 - Bodens Värmeverk - P18\3D-projekt\Inventor\Templates\Standard.idw", False)' This needs to be your template drawing.
'MsgBox (sks.Name)
Next
iLogicVb.RunExternalRule("Byt rithuvud")
End Sub
'============================================ My rule =======================================
Try
ThisDrawing.KeepExtraResources = True
'oDoc = ThisDoc.Document
Dim oSheets As Sheets
oSheets = oDoc.Sheets
Dim oSheet As Sheet
    oSheet.Activate
    oSymbol.Delete
    Else
    Next
	Try
'Dim oDrawDoc As DrawingDocument = ThisDrawing.Document ' Set a reference to the drawing document. This assumes a drawing document is active.
	Catch
		MessageBox.Show("Symbolen gick inte att byta, regeln kör vidare.", "Fel")
End Try
        Try
    End Try
    Try
    End Try
Next
Catch
	MessageBox.Show("Regeln gick inte att köra. Ritningen sparas som dwg.", "Fel")
End Try
Try
	If iProperties.Value("Project", "Revision Number") = "" Or
	iProperties.Value("Project", "Revision Number") = " " Or
	iProperties.Value("Project", "Revision Number") = "-"
	r = 1
	If r <> 1 'Om det finns rev så är r INTE = 1.
	ThisDoc.Document.SaveAs(ThisDoc.Path & "\" & ThisDoc.FileName(False) & " Rev " & iProperties.Value("Project", "Revision Number") & (".dwg") , True)
	Else
Catch
End Try
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
ThisApplication.ActiveView.Fit
Johan Sweden
Message 11 of 16
bradeneuropeArthur
change to this:
Public Sub Main()
  a = ThisApplication
'sks = temp.SketchedSymbolDefinitions.Item(1)
'MsgBox (sks.Name)
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 16
autodeskpelinder
I get the same error when I run our rules together.
It doesn't like:
"Dim a As Application".
I still get this error:
Google translate:
The application is ambiguous. Imported from the namespaces or types Inventor, System.Windows.Forms.
Maybe it is because I also use "ThisApplication.ActiveDocument" later in the code. But I tried to change my oDrawDoc to b, but it is the same.
First your:
  a = ThisApplication
Then in mine:
Johan Sweden
Message 13 of 16
bradeneuropeArthur
For me it works!
What version of inventor are you using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 16
autodeskpelinder
It is okay. I can run my rule from yours, so I don´t need to have it all in one rule.
But it would be nice to run it in one rule and replace more then one symbol at that rule too.
Thank you for your help.
Strange that you can run this:
Public Sub main()
  a = ThisApplication
'MsgBox (sks.Name)
Next
Try
Dim oSheet As Sheet
    oSheet.Activate
    oSymbol.Delete
    Else
    Next
	Try
	Catch
End Try
        Try
    End Try
    Try
    End Try
Next
Catch
End Try
Try
	r = 1
	Else
Catch
End Try
' JOPE 2016-03-30  2018-02-21
End Sub
Johan Sweden
Message 15 of 16
bradeneuropeArthur
Try the following:
and take a look where the error occurs
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 16
autodeskpelinder
It is still the same 😞
Please see the attached picture.
Johan Sweden
