Replace Reference in vb net
Hi All,
how to replace references in VB Net
Sub ReplaceFile(parent As String, oldfilename As String, newfilename As String)
        Dim oDoc As Inventor.Document
        oDoc = OpenFileCad(parent)
        If IsNothing(oDoc) Then
            Exit Sub
        If Not FileExists(newfilename) Then
            Exit Sub
        Dim allReferencedFiles As Object
        allReferencedFiles = oDoc.File.ReferencedFileDescriptors
        Dim ofd As FileDescriptor = Nothing
        oldfilename = oldfilename.ToLower
        Dim t As String = ""
        For Each ofd In allReferencedFiles
            Debug.Print(ofd.FullFileName & "  " & FileExists(ofd.FullFileName).ToString)
            t = ofd.FullFileName.ToLower
            If t = oldfilename Then
		ofd.ReplaceReference(newfilename)
                Exit For
        Next
End Sub
I tried with this code but does not work
Thanks Regards
Sub ReplaceFileApp(parent As String, oldfilename As String, newfilename As String)
        Dim oADoc As ApprenticeServerDocument
        Dim oApprentice As ApprenticeServerComponent
        oApprentice = New ApprenticeServerComponent
        oADoc = oApprentice.Open(parent)
        Dim oFD As FileDescriptor
        For Each oFD In oADoc.File.ReferencedFileDescriptors
            If oFD.FullFileName.ToLower = oldfilename.ToLower Then
                oFD.ReplaceReference(newfilename)
                oADoc.Update
        Next
    End Sub
MechMachineMan
1. Replaced file references will not stick in apprentice as you cannot save in apprentice
2. Files need to have shared ancestry to be able to replace them using that method. An alternative is to use Occurrence.Replace()
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
adam.nagy
Autodesk Support
Autodesk Support
Just an FYI about this article which might also be useful:
http://adndevblog.typepad.com/manufacturing/2016/03/replacereference-vs-filesaveas-vs-onfileresoluti...
Cheers,
Adam Nagy
Autodesk Platform Services
