Remove time portion of Date property value
I have a rule that grabs the value of a particular custom date property and sets another custom date property to that value when the rule is run.
Date Property B = Date Property A
My problem is this: sometimes the value of Date Property A contains the time. When I copy this value to Property B, and property B is used to create a folder path, it causes problems. Is there a way I can strip the time out of the property value? BTW, the time does not show in the properties dialog in IV.
Custom Property dialogCustom Property dialog
Actual value of propertyActual value of property
My code looks like this:
'Some Code
oToday = iProperties.Value("Custom", "Rev Date")
iProperties.Value("Custom", "Dwg Request Date") = oToday
'Some Code
If there was some string split function I could perform on oToday, to strip the time off the end it would be great.
Anybody have any ideas?
cmcconnell
Sorry - this was posted by me with the wrong account. :(Smiley Sad
Mechanix Design Solutions inc.
lmc.engineering
Hi @cmcconnell
You can use a split function on the string and take the first instance of the new string:
SyntaxEditor Code Snippet
oToday = "11/2/2018 9:53:25 AM"
myString = oToday
sDate = myString.Split(" ") (0)
bradeneuropeArthur
  1. Today.year
  2. Today.month
  3. Today.day
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
cmcconnell
I was able to get this to work using your solution - thanks!
bradeneuropeArthur
maybe this is much easier
msgbox (date.Today)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
