Drawing View Update for a Part File
Scott.Hallmark
Scott.Hallmark
I am trying to find code that will do what this button does.  Trying to update a part file view in a DWG, after I run a copy/replace code of a sheet.  I've looked all over and cannot find it here in the forum or anywhere else on the web.
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
JamieVJohnson2
try this:
        Dim drawDoc As Inventor.DrawingDocument = CreateDrawingDoc()
        drawDoc.Update()
        drawDoc.Update2(True)
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Scott.Hallmark
I get this:
Type 'Inventor.DrawingDocument' is not defined.
JamieVJohnson2
Inventor.Drawing document is defined using the vb.net Autodesk.Inventor.Interop name from file Autodesk.Inventor.Interop.dll
For most ALL Inventor programming environment it should already be loaded (vb.net, vba, and iLogic) should all already understand this namespace.
NachoShaw
Hi
you still need to assign a document to the member
VBA
Dim oDoc as DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
VB.Net
Private oDoc as Inventor.DrawingDocument = InvDoc 'where InvDoc has been created when the app starts
I did write a code to do this properly as we always found that it was better to open the underlying part / assembly and do an update. The code opened the part / assembly invisible, updated it properly, saved it and closed it then updated the drawing.
If i find it, i will post it as i made it for another Company a while back
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
JamieVJohnson2
Normally I would agree that assigning the member is important.  I expected him to already have that down.
However, the second issue raised here is 'type not defined'.  That's more fundamentally lower level.  If he is using iLogic or vba, that type should already be defined (so I wouldn't know how to solve it).  If he is using a .Net project outside, then he needs to add reference to that dll.
