Display "Extrude" dialog box using a Inventor VBA Macro
isocam
isocam
Can anybody help?
Does anybody know how to display the "Extrude" dialog box using a Inventor VBA Macro?
Please see the attached picture.
Many thanks in advance!!!!
Darren
bshbsh
call:
ThisApplication.CommandManager.ControlDefinitions.Item("PartExtrudeCmd").Execute
isocam
The code, shown below, shows the extrude description (help) dialog box rather than the extrude dialog box that I am after. Do I need to select the extrusion firstly and if so, how?
Kindest Regards
Darren
bradeneuropeArthur
Public Sub ExtrudeWithDialog()
Dim CmdMan As ControlDefinition
    Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("PartDMExtrudeCmd")
    'PartDMExtrudeCmd
    CmdMan.Execute
        CmdMan.Execute2 (True)
End Sub
This shows the same behavior as in default inventor!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
