- Mute
- Permalink
- Report
Hi All,
I have a part that can change it's shape when a user sets parameters in an iLogic form within the part. Once the part's parameters are set the user can trigger a save rule and the parts saves out to a new file. Once this happens, I want to be able to remove the iLogic form from the new part. Also there is an embedded spreadsheet that I would also like to remove. I'm doing this so that the part cannot be changed and to lighten the part file. Note I already strip out all of the ilogic rules from the new part file.
So in summary, is there a way to remove an iLogic form and or a spreadsheet from a part file using iLogic code?
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Using Inventor 2018
