Regarding System.Runtime.Interopservices.COMException
public void PackAndGoSample()
            PackAndGoComponent packAndGoComp = new PackAndGoComponent();
            PackAndGo packAndGo = packAndGoComp.CreatePackAndGo("C:\\Temp\\Source\\Assembly1.iam", "C:\\Temp\\Destination");
            // Set the design project. This defaults to the current active project.
            packAndGo.ProjectFile = "C:\\Temp\\Source\\Test.ipj";
            string[] refFiles = new string[] { };
            object refMissFiles = new object();
            // Set the options
            packAndGo.IsSkippingLibraries = true;
            packAndGo.IsSkippingStyles = true;
            packAndGo.IsSkippingTemplates = true;
            packAndGo.IsCollectingWorkgroups = false;
            packAndGo.IsKeepingFolderHierarchy = true;
            packAndGo.IncludeLinkedFiles = true;
            // Get the referenced files
            packAndGo.SearchForReferencedFiles(out refFiles, out refMissFiles);
            // Add the referenced files for package
            packAndGo.AddFilesToPackage(refFiles);
            // Start the pack and go to create the package
            packAndGo.CreatePackage();
Above is the code which I am using and for the line
PackAndGoComponent packAndGoComp = new PackAndGoComponent(); I am getting an System.Runtime.Interoservices.COMException error
Please help me in resolving this issue.
Thank you.
bradeneuropeArthur
What version of inventor are you using?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hello Sir,
I am using Inventor version 2015 and visual studio 2015
Thank you.
bradeneuropeArthur
Are you familiar with Vb.net too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Hello sir,
Ya I am familiar with vb.net but I not getting a solution to resolve System.Runtime.Interop.COMException  please help.
Thank you.
Amruta
bradeneuropeArthur
you need something like this added:
oPacknGo.SearchForReferencingFiles(sRefFiles, sRefcingFiles, False, dirio.Parent.FullName & "\_Dwg")
        Dim xa = New String(sRefFiles.Length + sRefcingFiles.Length - 1) {}
        sRefFiles.CopyTo(xa, 0)
        sRefcingFiles.CopyTo(xa, sRefFiles.Length)
        'oPacknGo.AddFilesToPackage(sMissFiles)
        ' Start the pack and go to create the
        oPacknGo.AddFilesToPackage(xa)
        'MsgBox(xa.Length)
        oPacknGo.CreatePackage(True)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
