Rectangular Balloon Override doesn't work
NSBowser
NSBowser
When attempting to override a balloon style with the API, I would like to create a rectangular balloon (as is possible with the manual balloon edit options) using the following process:
   oBalloon.SetBalloonType(kRectangleBalloonType) ' or 48135
However, doing so creates a balloon with a triangular frame, which isn't even one of the listed options.
To check the values of the enum, I created a box balloon manually, and used the following code, which did return 48135:
   oBalloon.GetBalloonType(balloonType, data)
Any thoughts on what is wrong?
It appears to be a problem with the API, so I'm not even sure there is a work around possible...
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
philip1009
That does look like a glitch with the API, the API guide for this has values from 48129-48135, maybe using one of the other numbers or balloon types might get you the result you want.  It is weird you'd get a triangle, usually that shape is used for revision notation.  Unless you have a need to have different shaped balloons in your drawings, you can change the balloon shape in the Styles Editor.
johnster100
is this fixed in inventor 2019?
the other numbers you suggest didn't work for me.
thanks,
John
mat_hijs
This still seems to be an issue in Inventor 2024. @johnsonshiue Could you have a look at this so it could get fixed?
bradeneuropeArthur
In the i-logic it is not listed and that is weird:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
