Recognize bending in sheet metal parts
Message 1 of 37
Is it possible with VBA or ilogic that Inventor can recognize if a sheet metal part is just flat or that a bending exist?
I would like an automatic Iproperty of choice to be filled in if there is a bend in the plate part..
This would make sorting much easier for me.
I hope someone can help me with this.
Thanks in advance.
Regards.
Jeffrey
Replies (36)
Message 2 of 37
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim sm As SheetMetalComponentDefinition
Set sm = b.ComponentDefinition
MsgBox sm.Bends.Count
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 37
Thanks for your help.
Where should I indicate in which iProperty it must be completed?
I don't have so much experience in these thinks yet..
Jeffrey
Message 4 of 37
bradeneuropeArthur
this:
Public Sub main()
If sm.Bends.Count > 0 Then
Dim customProp As Property
On Error Resume Next
Set customProp = b.PropertySets.Item(4).Item("CustomProp").Value = "CustomProp"
Set customProp = b.PropertySets.Item(4).Add("Bend Exist", "CustomProp")
End If
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 37
SyntaxEditor Code Snippet
Public Sub Main()
Set customProp = b.PropertySets.Item(4).Item("Bending").Value = "CustomProp"
Set customProp = b.PropertySets.Item(4).Add("Bend Exist", "Bending")
End If
End Sub
Did I fill it in so well? (name iproperty = bending)
Because I get some errors..
Rule Compile Errors in Bending, in 21629.ipt
Error on Line 4 : Let- en Set-toewijzingsinstructies worden niet langer ondersteund.
Error on Line 7 : Let- en Set-toewijzingsinstructies worden niet langer ondersteund.
Error on Line 10 : Let- en Set-toewijzingsinstructies worden niet langer ondersteund.
Error on Line 12 : Methodeargumenten moeten tussen haakjes worden geplaatst.
Error on Line 16 : Het sleutelwoord benoemt geen type.
Error on Line 18 : Let- en Set-toewijzingsinstructies worden niet langer ondersteund.
Error on Line 19 : Let- en Set-toewijzingsinstructies worden niet langer ondersteund.
Jeffrey
Message 6 of 37
bradeneuropeArthur
the code is for VBA:
for illogic:
remove all "set"
Public Sub Main()
a = ThisApplication
customProp = b.PropertySets.Item(4).Item("Bending").Value = "Bend Exist"
End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 37
I still have a error left..
Sorry but I can not fix this myself Smiley Indifferent
Error on Line 11 : Methodeargumenten moeten tussen haakjes worden geplaatst.
Error on Line 15 : Het sleutelwoord benoemt geen type.
Message 8 of 37
bradeneuropeArthur
set your project to "straight Vba Code"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 37
I have adjusted that now.
One error left:
Rule Compile Errors in Bending, in 21634.ipt
Error on Line 1 : De instructie is niet geldig in een naamruimte.
Message 10 of 37
bradeneuropeArthur
Dim a As inventor.Application
a = ThisApplication
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 37
Still have a error..
This is the code right now:
Public Sub Main()
Dim a As Inventor.Application
End If
End Sub
Message 12 of 37
bradeneuropeArthur
tested and it works now:
Public Sub Main()
a = ThisApplication
MsgBox (sm.Bends.Count)
Dim customProp As Inventor.Property
End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 37
Strange..
If I do Save & Run i do not get any errors but nothing happens when I look to the custom properties..
When I run the rule again in the Ilogic browser I get the error..
Error on Line 1 : De instructie is niet geldig in een naamruimte.   (The statement is not valid in a namespace.)
Jeffrey
Message 14 of 37
bradeneuropeArthur
Remove the public sub main and the end sub from this module...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 37
Sorry but I realy do not understand what you mean..
I tried diferent thinks but keep getting errors everytime.
Could you possibly place the complete code as it should be?
Jeffrey
Message 16 of 37
bradeneuropeArthur
I already provided you the working Code but there must be something wrong or different on your side. I am far away from my desktop so I can help you on this earliest Monday. Could you please send me a private message with a link to this topic so I will not forget.
Regards.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 37
bradeneuropeArthur
could you please provide me the complete code you are using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 37
I used the same code as the one that works for you.
Public Sub Main()
a = ThisApplication
End If
End Sub
Jeffrey
Message 19 of 37
bradeneuropeArthur
could you please provide the ipt too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 37
I have attached the file.
I also tested it with a different file.
Jeffrey
