Reading iProperty Values and naming them as Files
Hello Guys,
So we've been working on naming our drawing files from our ".ipt" files into ".dxf" files using iLogic. What we want to do is to generate Folders named with parts Material ( we are using sheetmetal so say like "Galvanized Steel - 2mm" so we will use the Material and the Thickness to name the Folder and then the parts drawing in a similar manner. We could name the dxf s with the "FilePath" but thats not very useful because we couldn't read the iProperty.Material or Thickness.
We've spent around 4-5 hours in the forums but couldn't find a good solution to do this. Help is much appreciated. Thanks.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
