Read file iProperty from Vault
Message 1 of 29
How would I go about reading the Revision number iProperty, of the active inventor file, from Vault using either VBA or VB.net?
Replies (28)
Message 2 of 29
Sorry, just read that back and its not very clear.
I'm trying to read the iProperty value of the active Inventor document as it is in Vault, using the Inventor application either through the iLogic or VBA environment. I wish to compare the iProp value of the local file vs the vaulted version.
Message 3 of 29
bradeneuropeArthur
What version of inventor and vault ate you using.
Then I can take a look at the coding.
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 29
bradeneuropeArthur
After your info I could take a look at the coding.
Because te coding is different for each version release.
Thank you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 29
I'm using Inventor 2017 Pro and Vault Basic 2017
Message 6 of 29
bradeneuropeArthur
  • Create a new inventor 2017 add in
  • Make the following additional references
Imports Inventor
Imports System.Runtime.InteropServices
Imports Autodesk.Connectivity.Extensibility.Framework
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServicesTools
Imports Connectivity.InventorAddin.EdmAddin
Imports VDF = Autodesk.DataManagement.Client.Framework
Private moDocSvc As Autodesk.Connectivity.WebServices.DocumentService
  • Add this code to your "SetupUserInterface"
Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
			Dim strVaulrServerName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Server
            Dim strVaultName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.VaultName
            Dim strVaultUserName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.UserName
            Dim strVaultPassword As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Password
            Dim results As VDF.Vault.Results.LogInResult
            results = VDF.Vault.Library.ConnectionManager.LogIn(strVaulrServerName, strVaultName, strVaultUserName, "", VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
            Dim conn As VDF.Vault.Currency.Connections.Connection = Nothing
            If results.Success Then
                conn = results.Connection
            End If
            moDocSvc = conn.WebServiceManager.DocumentService
        End Sub
  • Create a Button
Private Sub m_ButtenDef_OnExecute(Context As Inventor.NameValueMap) Handles m_LargeButtonDefinition.OnExecute, m_SmallButtonDefinition.OnExecute
            Dim Odoc As Document = m_inventorApplication.ActiveDocument
            Dim VaultFile As String = Odoc.FullFileName.Replace("YOU LOCAL VAULT PATH", "$")
            VaultFile = VaultFile.Replace("\", "/")
            Dim hh() As Autodesk.Connectivity.WebServices.File = moDocSvc.FindLatestFilesByPaths(New String() {VaultFile})
            MsgBox(" THE REVISION OF THE FILE = " & hh(0).FileRev.Label)
        Exit Sub
Hope this will help you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 29
Thank you for you reply. I've managed to create a project from the Inventor 2017 add-in template, compile it and see it load in Inventor (that's the furthest I've ever got to in creating my own add-in !!)
I'm now running into errors however when attempting to add your code, see attached image. It's like its not recognizing the imported references.
Could you perhaps look at my project file and see where I'm going wrong? (see attached)
thanks
Message 8 of 29
bradeneuropeArthur
I will take a look at your project ASAP.
but first set these references in your project (See Picture)References add in.PNG
Let me know if I need to take a look at the coding or if it has been solved herewith?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 29
Thanks, that's taken care of the references. Just down to 3 errors left now (see attached image)
Appreciate the help!
Message 10 of 29
@bradeneuropeArthur
I think I traced it back to here. I'm not sure how to reference an icon/bitmap for my button?
Message 11 of 29
bradeneuropeArthur
You need to add an icon to your project resources. Than add this with icontoipicture to your button.
If needed I can show you how tommorow.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 29
bradeneuropeArthur
The following:
  • add an icon to your resources of the project.
  • Create a button picture by using IconToPicture method using this resource icon. The green marked is only a marked undeline message and will not lead into errors.IconToIPuctureIconToIPucture
If this is not solving your problem today, I will take a look at the complete coding tomorrow.
Hope this will help you with your problem.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 29
Great thank you, I managed to add an image (jpeg) to my project resources and use it on this line:
Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.iPropVault)
This got rid of the errors and I then built the solution again. It built successfully but I got a warning also, not sure if that affects anything?
I've noticed the dll file updates but the .ADDIN file doesn't.
The good news is I can see the button now in Inventor and clicking on it produces a messagebox I added to the start of the Sub to display Odoc.FullFileName Smiley Happy
The bad news is, the image is not appearing on the button and I'm not getting the message box showing the revision of the vaulted file.
Any clues as to what could be happening?
Message 14 of 29
bradeneuropeArthur
The .Addin file is only an Xml File and will not change normally spoken, this is correct.
regarding the picture:
  • What framework are you using?
Regarding the revision:
  • are you logged in to the vault.
  • To test you could put msgbox into the code to look how far you are coming in the process without errors.
Otherwise send me the code as private message so I can take a look at it. or place the add in code as txt file here.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 29
I'm using .NET Framework 4.5
Attached code as .txt file
Getting as far as message box showing the active document full file name.
Unfortunately I'm only using VS express version so I can't debug by stepping through the code. I'm having to build the solution again each time and test in Inventor.
If there was an error on this line, is there any way to see it?
I'm assuming this is where the error is as it's not reaching the last messagebox of the button sub.
Message 16 of 29
P.s I am logged into Vault
Message 17 of 29
bradeneuropeArthur
You forgot to add the pictures to the button!
This will solve the button issue.
The rest I will take a look at later.
let me know if the icon button issue has been solved!
please copy and replace:
' Sample to illustrate creating a button definition.
            Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.iPropVault)
            Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
            m_sampleButton = controlDefs.AddButtonDefinition("Command Name", "Internal Name", CommandTypesEnum.kShapeEditCmdType, AddInClientID,"ButtonLargeDescription",
        "ButtonLargeToolTipText", oSmallIcon, oLargeI
con)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 29
bradeneuropeArthur
HI,
I assume that you are logging in with a password, or not.
if you are using a password then you also need it in your code.
please then replace the following line with this one.
            results = VDF.Vault.Library.ConnectionManager.LogIn(strVaulrServerName, strVaultName, strVaultUserName, strVaultPassword, VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
Did I t work?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 29
@bradeneuropeArthur
I have made that change to the line you suggested and still had no success.
I tried moving the contents of the SetupUserInterface sub into  the m_sampleButton_OnExecute private sub and it now gets to the last message box.
Although the FileRev.Label is blank Smiley Frustrated
I checked vault and it should have a value of "A"
see code below:
Private Sub m_sampleButton_OnExecute(Context As Inventor.NameValueMap) Handles m_sampleButton.OnExecute
Dim strVaulrServerName1 As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Server
Dim strVaultName1 As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.VaultName
Dim strVaultUserName1 As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.UserName
Dim strVaultPassword1 As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Password
Dim results1 As VDF.Vault.Results.LogInResult
results1 = VDF.Vault.Library.ConnectionManager.LogIn(strVaulrServerName1, strVaultName1, strVaultUserName1, strVaultPassword1, VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
Dim conn1 As VDF.Vault.Currency.Connections.Connection = Nothing
If results1.Success Then
conn1 = results1.Connection
MsgBox("Connected to Vault")
End If
moDocSvc = conn1.WebServiceManager.DocumentService
Dim Odoc As Document = g_inventorApplication.ActiveDocument
MsgBox(Odoc.FullFileName)
Dim VaultFile As String = Odoc.FullFileName.Replace("C:\_Vault-WIP", "$")
MsgBox(VaultFile)
MsgBox(hh(0).Name)
Exit Sub
End Sub
Message 20 of 29
bradeneuropeArthur
For my understanding:
The button icon issue has been solved?
the messages in green are given correct?
the messages in red is not given correctly, but messagebox is appearing?
End If
MsgBox(VaultFile)
MsgBox(hh(0).Name)
Exit Sub
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
