Read a list of files from excel and download/get them from vault using ilogic
phani.gampala
Message 1 of 16
phani.gampala
Hello everyone,
I have automated configuration that replaces a lot of parts from a excel file. All these parts are required to be in the local space of the user. I need to add a rule to my assembly that reads the list of parts from excel and downloads them from vault into the local space of the user. I am not familiar with vault API and am not good at VBA. I just started to write some complicated coding using Inventor API. Is it possible to achieve this...It is crucial for the automated model to work for all the users...
Any suggestion or direction is much appreciated.
Phani.
Replies (15)
Message 2 of 16
johnsonshiue
Hi! I am not sure if this is related. Please take a look at the following thread.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/get-file-from-vault/td-p/5514721
Many thanks!
Software Test Engineer
Message 3 of 16
phani.gampala
Thanks for the response @johnsonshiue,
I did not quite follow the conversation in that link. I think I have to create a dll file to mentiona reference in ilogic to access vault API, but I'm new to all of that!
Message 4 of 16
tyler.warner
@phani.gampala this is some iLogic code written in VB.NET that would get the files from Vault based on the cells in the Excel sheet. This is setup to be run in Inventor after it is logged into Vault. Those settings can be adjusted.
Additional Vault questions will get better response on the Vault Customization Forum (link) instead of this one.
AddReference "Connectivity.Application.VaultBase.dll"
AddReference "Autodesk.Connectivity.WebServices.dll"
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports Autodesk.Connectivity.WebServices
Imports ACW = Autodesk.Connectivity.WebServices
Imports ACWT = Autodesk.Connectivity.WebServicesTools
Imports VB = Connectivity.Application.VaultBase
Imports VDF = Autodesk.DataManagement.Client.Framework
Sub Main
	Dim oExcelList As ArrayList
	oExcelList = GoExcel.CellValues("C:\MY_WORKSPACE\FilesToGet.xlsx", "Sheet1", "A1", "A3")
	' Ex: "C:\MY_WORKSPACE\File.idw"
	For Each FullFileNameWithExtension In oExcelList
		AcquireVaultFile(FullFileNameWithExtension)
	Next
End Sub
Sub AcquireVaultFile(oFileName As String)
    Dim oVaultConn As VDF.Vault.Currency.Connections.Connection = VB.ConnectionManager.Instance.Connection
    If oVaultConn Is Nothing Then
        MsgBox("Not Logged In to Vault! Login first & repeat executing this rule.")
    End If
    Try
		' "C:\MY_WORKSPACE\" = Project Specified Working Folder.
        Dim oTemplateVaultPath As String = oFileName.Replace("C:\MY_WORKSPACE\", "$/")
        oTemplateVaultPath = oTemplateVaultPath.Replace("\", "/")
        Dim oVaultPaths() As String = New String() {oTemplateVaultPath}
        Dim oWebServFiles() As ACW.File = oVaultConn.WebServiceManager.DocumentService.FindLatestFilesByPaths(oVaultPaths)
        oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(oVaultConn, oWebServFiles(0))
        Dim oVaultSettings As New VDF.Vault.Settings.AcquireFilesSettings(oVaultConn)
        oVaultSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download
        oVaultSettings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = VDF.Vault.Currency.VersionGatheringOption.Latest
        oVaultSettings.AddFileToAcquire(oFileIteration, oVaultSettings.DefaultAcquisitionOption)
        Dim oVaultResults As VDF.Vault.Results.AcquireFilesResults = oVaultConn.FileManager.AcquireFiles(oVaultSettings)
    Catch ex As Exception
        MsgBox("Could not download file: " & vbNewLine & oFileName)
	End Try
End Sub
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 5 of 16
phani.gampala
Thank you very much @tyler.warner. The code is running but comes up with the error message /exception message in the try catch loop always. It is unable to find any part in vault for reasons I don't understand.
Message 6 of 16
tyler.warner
If you're including this in an add-in, then step thru the code while debugging to see which line errors out.
If you're doing this in iLogic, in the try catch loop, you can either add a message box between lines or add logger info. Let me know where the error is occurring for you & we can correct it.
Message 7 of 16
phani.gampala
Hi @tyler.warner,
Thanks for the response. The rule runs through and gives "could not download file" every single time.
However, when I tested with a msgbox as in the screenshot attached. Test Msgbox ("here") shows up at every line of code except when it is placed after the acquire files line (see screenshot).
Message 8 of 16
tyler.warner
So the acquire files is the part that isn't working. I'm guessing it has something to do with the file name or file location.
The example above has the full file name with the path (Ex: "C:\MY_WORKSPACE\File.idw) included in the cell specifying which drawing you want (lines 16 & 17). You can adjust that if needed.
The change from the working folder location to the Vault location (lines 33-35) could be causing issues. For clarity, the "$/" stands for the "Project Explorer" location in your Vault (line 34). In the working folder, the slashes are a different direction than the slashes for the Vault location (line 35) so the command swaps those.
Verify some of those things. If still not working then maybe post your code & excel file.
Message 9 of 16
phani.gampala
Hi @tyler.warner,
Thanks for the explanation. I have verified those parts of the code. I'm getting the same result. I have attached the code and the excel file like you mentioned. I think , I'm missing something basic. Will the code check for the file through different folders under Project explorer in vault. I have also tried putting a file directly under Project explorer in vault and tried to download that with code but it did not work.
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports AWS = Autodesk.Connectivity.WebServices
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency'.Properties
AddReference "Autodesk.DataManagement.Client.Framework.dll"
Sub Main
Dim excelFilelocation As String
excelFilelocation = "L:\Phani\RC REPLACEMENT.xlsx"
oExcelList = GoExcel.CellValues(excelFilelocation, "Sheet3", "A1", "A3")
Next
End Sub
End If
Try
Dim oTemplateVaultPath As String = oFileName.Replace("C:\Users\phanig\Documents\Vault\", "$/")
Dim oWebServFiles() As AWS.File = oVaultConn.WebServiceManager.DocumentService.FindLatestFilesByPaths(oVaultPaths)
Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(oVaultConn, oWebServFiles(0))
End Try
End Sub
Message 10 of 16
tyler.warner
Hey @phani.gampala try to correct your file names & file locations per instructions below.
Right now, the way they are in your code & Excel file, it will not work as you can tell with testing.
     ' (This should be where the Excel file is stored on your computer)
     ' (L:\Phani\RC REPLACEMENT.xlsx\0092230.ipt   (from Excel) will not be changed..... here's the issue)
     ' (If the file   0092230.ipt   is stored in this folder   C:\Users\phanig\Documents\Vault\   )
     ' (Then the Excel cell needs to contain   C:\Users\phanig\Documents\Vault\0092230.ipt   )
     ' (Then the below lines will change it to search in your Vault for   Project Explorer/0092230.ipt   )
Message 11 of 16
phani.gampala
Thank you @tyler.warner, the code works well. Thank you for the explanation.
That was a silly mistake from me. Is there a way I can search through folders for each part instead of having to mention the path for each file? We have numerous folders in vault which has made this process complicated. Lastly, how can I learn Vault API and learn to use it in ilogic?
Message 12 of 16
ls-4453
If you follow the instructions on the Autodesk website, you can install the Vault SDK and get access to the Vault SDK Help File.
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
You probably want to use FindFilesBySearchConditions.
https://justonesandzeros.typepad.com/blog/2012/09/finding-by-search-conditions.html
The example searches by the property "CheckoutUserName", you want to use "ClientFileName".
Dim filePropDefs As ACW.PropDef()
filePropDefs = oVaultConn.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
Dim filenamePropDef As ACW.PropDef
filenamePropDef = filePropDefs.Single(Function(n) n.SysName = "ClientFileName")
Message 13 of 16
ls-4453
This code should work.
' VB.NET
Dim filePropDefs As ACW.PropDef() = _
Dim fileNamePropDef As ACW.PropDef = _
    filePropDefs.[Single](Function(n) n.SysName = "ClientFileName")
' SrchOper 3 => equals
Dim fileNameToFind As New ACW.SrchCond() With { _
       .PropDefId = fileNamePropDef.Id, _
       .PropTyp = ACW.PropertySearchType.SingleProperty, _
       .SrchOper = 3, _
       .SrchRule = ACW.SearchRuleType.Must, _
       .SrchTxt = "YOUR FILE NAME GOES HERE" _
Dim bookmark As String = String.Empty
Dim status As ACW.SrchStatus = Nothing
Dim totalResults As New List(Of ACW.File)()
While status Is Nothing OrElse totalResults.Count < status.TotalHits
       Dim results As ACW.File() = _
          oVaultConn.WebServiceManager.DocumentService.FindFilesBySearchConditions( _
           New ACW.SrchCond() {fileNameToFind}, _
           Nothing, Nothing, False, True, bookmark, _
              status)
       If results IsNot Nothing Then
              totalResults.AddRange(results)
       Else
              Exit While
       End If
End While
' total results now has the results
Message 14 of 16
phani.gampala
Hi @ls-4453,
Thank you very much. The code runs without errors but does not download the file. I'm missing something here.
' VB.NET
Dim filePropDefs As ACW.PropDef() = oVaultConn.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
Dim fileNamePropDef As ACW.PropDef = filePropDefs.[Single](Function(n) n.SysName = "ClientFileName")
Dim fileNameToFind As New ACW.SrchCond() With { .PropDefId = fileNamePropDef.Id, .PropTyp = ACW.PropertySearchType.SingleProperty, _
.SrchOper = 3, .SrchRule = ACW.SearchRuleType.Must, .SrchTxt = "0108788.ipt"}
Dim results As ACW.File() = oVaultConn.WebServiceManager.DocumentService.FindFilesBySearchConditions( New ACW.SrchCond() {fileNameToFind}, _
Nothing, Nothing, False, True, bookmark, status)
Else
Exit While
End If
End While
Message 15 of 16
ls-4453
Yes, that code only gets you a list of Vault files that match the search. You need to use the Vault API to download them (https://justonesandzeros.typepad.com/blog/2013/05/how-to-acquire-files.html).
Message 16 of 16
ls-4453
This code should do what you want.
Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings
oSettings = New VDF.Vault.Settings.AcquireFilesSettings(oVaultConn, False)
For Each file As ACW.File In totalResults
	Dim fileToDownload As VDF.Vault.Currency.Entities.FileIteration
	fileToDownload = New VDF.Vault.Currency.Entities.FileIteration(oVaultConn, File)
	oSettings.AddFileToAcquire(fileToDownload, VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download)
Next
Dim oAcquireFilesResults As VDF.Vault.Results.AcquireFilesResults
oSettings.OptionsRelationshipGathering.FileRelationshipSettings.IncludeChildren = True
oSettings.OptionsRelationshipGathering.FileRelationshipSettings.RecurseChildren = True
oSettings.OptionsRelationshipGathering.FileRelationshipSettings.VersionGatheringOption = VDF.Vault.Currency.VersionGatheringOption.Latest
oSettings.OptionsResolution.OverwriteOption = VDF.Vault.Settings.AcquireFilesSettings.AcquireFileResolutionOptions.OverwriteOptions.NoOverwrite
oAcquireFilesResults = oVaultConn.FileManager.AcquireFiles(oSettings)
