Automatic Ordinate Set Dimensions
clive.w66LR9
Message 1 of 8
clive.w66LR9
Hello all,
The Below code creates a General Dimension between to defined faces,
I have tried but with no luck to change this to work with a Ordinate Set Dimension.
With "_End Stud:1" being the origin.
I tried to use the link below to get it work.
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-488C8D53-8A2E-4A83-8181-C6191DC873B0https...
It seems to be a issue with defining a (DrawingCurveSegment)
Dim Doc As DrawingDocument
Doc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = Doc.ActiveSheet
Dim oView As DrawingView
oView = oSheet.DrawingViews(1)
Dim oAsmDoc As AssemblyDocument
oAsmDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oCompDef  As AssemblyComponentDefinition
oCompDef = oAsmDoc.ComponentDefinition
Dim FPColl As ObjectCollection
Dim OverallColl As ObjectCollection
Dim oText As Point2d
Dim S1 = oCompDef.Occurrences.ItemByName("_End Stud:1")
Dim S2 = oCompDef.Occurrences.ItemByName("_Left Stud:1")
FPColl = ThisServer.TransientObjects.CreateObjectCollection
OverallColl = ThisServer.TransientObjects.CreateObjectCollection
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(S1.Definition.Document)
Dim S1Face As Face = namedEntities.FindEntity("Face1")
Call S1.CreateGeometryProxy(S1Face, oSketchProxy)
Dim S1Curve = oView.DrawingCurves(oSketchProxy)
oIntent = oSheet.CreateGeometryIntent(S1Curve.Item(1))
Call OverallColl.Add(oIntent)
namedEntities = iLogicVb.Automation.GetNamedEntities(S2.Definition.Document)
Dim S2Face As Face = namedEntities.FindEntity("Face1")
Call S2.CreateGeometryProxy(S2Face, oSketchProxy)
Dim S2Curve = oView.DrawingCurves(oSketchProxy)
oIntent = oSheet.CreateGeometryIntent(S2Curve.Item(1))
oText = ThisServer.TransientGeometry.CreatePoint2d(oView.Center.X - oView.Width / 2, oView.Center.Y - oView.Height / 2)
oText.Y = oText.Y - 1
Call oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oText, OverallColl.Item(1), OverallColl.Item(2)).CenterText
 any help will be appreciated
Replies (7)
Message 2 of 8
clive.w66LR9
for anybody that could use it, i got it to work
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'[S1
'[S2
oText1 = ThisServer.TransientGeometry.CreatePoint2d(oView.Center.X - oView.Width / 2, oView.Center.Y - oView.Height / 2)
'Create Ordinate Dimenson
Dim geomIntents As ObjectCollection
geomIntents = ThisApplication.TransientObjects.CreateObjectCollection
Call geomIntents.Add(OverallColl.Item(1))
Call geomIntents.Add(OverallColl.Item(2))
Call oSheet.DrawingDimensions.OrdinateDimensionSets.Add(geomIntents, oText1, kHorizontalDimensionType)
Message 3 of 8
SebastianMK
Thanks for Sharing this Code 👍
It works great if the Occurences are in the first Level of the Assembly.
In my Case the Occurences with the Named Faces are inside of an Subassembly in my Main Assembly.
And I get the Error:  Inventor.ComponentOccurrences.get_ItemByName(String Name) when running the Rule.
Does someone have an idea how to change the rule to run thru all the Levels of the Assembly and find the Named Face with  Occurence.ItemByName
This is the code so far:
Dim oSheet As Sheet
'The Problem here might be that the Occurence is not in the first Level of the Assembly but in a subassembly
'Maybe we need to define in which Parent Occurence we want to look (Stand Occ 1 or Stand Occ 2)
Dim S1 = oCompDef.Occurrences.ItemByName("50.09.0062 - Plate:1") Dim S2 = oCompDef.Occurrences.ItemByName("50.09.0062 - Plate:1") FPColl = ThisServer.TransientObjects.CreateObjectCollection OverallColl = ThisServer.TransientObjects.CreateObjectCollection 'If we could work with our Points that we know insted of Faces then it would work '[S1 Dim namedEntities = iLogicVb.Automation.GetNamedEntities(S1.Definition.Document) Dim S1Face As Face = namedEntities.FindEntity("Start") Call S1.CreateGeometryProxy(S1Face, oSketchProxy) Dim S1Curve = oView.DrawingCurves(oSketchProxy) oIntent = oSheet.CreateGeometryIntent(S1Curve.Item(1)) Call OverallColl.Add(oIntent) '] '[S2 namedEntities = iLogicVb.Automation.GetNamedEntities(S2.Definition.Document) Dim S2Face As Face = namedEntities.FindEntity("End") Call S2.CreateGeometryProxy(S2Face, oSketchProxy) Dim S2Curve = oView.DrawingCurves(oSketchProxy) oIntent = oSheet.CreateGeometryIntent(S2Curve.Item(1)) Call OverallColl.Add(oIntent) '] oText1 = ThisServer.TransientGeometry.CreatePoint2d(oView.Center.X - oView.Width / 2, oView.Center.Y + oView.Height) 'Create Ordinate Dimenson Dim geomIntents As ObjectCollection geomIntents = ThisApplication.TransientObjects.CreateObjectCollection Call geomIntents.Add(OverallColl.Item(1)) Call geomIntents.Add(OverallColl.Item(2)) Call oSheet.DrawingDimensions.OrdinateDimensionSets.Add(geomIntents, oText1, kHorizontalDimensionType)
Best Regards
Sebastian
Message 4 of 8
clive.w66LR9
try change
To
 oView.ReferencedDocumentDescriptor.AllReferencedDocuments
Message 5 of 8
SebastianMK
Unfortunately AllReferencedDocuments is not a Member of the DocumentDescriptor
Message 6 of 8
clive.w66LR9
I’m not sure if it’s even going to help your overall problem,
but you can get down to the level like this
Dim  refDoc As Document In oAsmDoc.ReferencedDocuments
And so on
Message 7 of 8
krishnaprasad.veedu
@SebastianMK : Hi, were you able to get a solution for your issue, I have got a similar issue when my named entities are inside a subassembly? any luck? thanks.
Message 8 of 8
JMGunnar
If you want too GetIntet in subassembly from drawingview
LeftPoint = oView.GetIntent({"Bottomsection","Flatbar Diagonales" },"LeftFace" )
 FlatBar Diagonals is component in subassembly Bottomsection
@krishnaprasad.veedu @SebastianMK
Best Regards Johan
