"Created:" in an idw
Good Morning, All.
My question is this: How can I insert this field from iProperties into an IDW (see attached .png file)?
Yes, we can insert the "Creation Date" field, but users can forget to update this.
Thank You
MechMachineMan
1. Change your template for that field to be a prompted entry. OR Establish a Custom iProp for this OR Have the code overwrite the Creation Date Property field
2. Write said program that uses: File.GetCreationTime(oDocInQuestion)
... This is actually going beyond iLogic and using VBA/vb.net. You can find more on this if you google "msdn + vb.net"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thank you, Justin, for your input.  I will try the visual basic approach, and let you know how it works.
