iLogic - Batch Part Parameter Editor Rule in Assembly
I was hoping I could get some advice about an iLogic rule I wrote for Inventor 2016.  My goal is to run it in an assembly, have it look at each part contained in that assembly, specify parameters (G_L, G_W, G_T) and have it configure them.  Because this configuration drives the final format of the BOM (which can vary from client to client) I often find myself tending to this task manually. I am fairly new to i Logic, but my thought process of accomplishing this is as follows:
1. look at only parts in the document
2. search for a "G_L" parameter
3. set it to export
4. set units to feet
5. Set fractional
6. Set 1/16 precision.
7. (FUTURE STEP) Continue to G_W and G_T parameters and repeat steps 3 thru 6
Below is the Rule I am struggling to troubleshoot:
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim partDoc As Document
For Each partDoc In openDoc.AllReferencedDocuments
     'look at only part files
     If partDoc.DocumentType = kPartDocumentObject Then
     'format file name
     Dim FNamePos As Long
     FNamePos = InStrRev(partDoc.FullFileName, "\", -1)
     Dim docFName As String
     docFName = Right(partDoc.FullFileName, Len(partDoc.FullFileName) - FNamePos)
          Dim userParams As UserParameters
          For Each userParams In partDoc.ComponentDefinition.Parameters.UserParameters
          Next userParams
          p = Parameter.Param("G_L")
          p.ExposedAsProperty = True
          Dim cFormat As CustomPropertyFormat = p.CustomPropertyFormat
          cFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType
          cFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
          cFormat.Units = "ft"
     'rebuild to update the display
     partDoc.Rebuild
Next
iLogicVb.UpdateWhenDone = True
Here is the error I receive when I run the rule:
Error in rule: Rule0, in document: Assembly1
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.UserParameters'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{2FF370FA-BB1C-4C92-BB10-06D94CC8F8F3}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Thank you!
MechMachineMan
openDoc = ThisApplication.ActiveDocument
     'format file name
          Dim userParam As UserParameters
          For Each userParam In partDoc.ComponentDefinition.Parameters.UserParameters
                If userParam.Name = "G_L" OR userParam.Name = "G_W" OR userParam.Name = "G_T"
                      userParam.ExposedAsProperty = True
                     Dim cFormat As CustomPropertyFormat = userParam.CustomPropertyFormat
                 End if
           Next
     partDoc.Update
Next
openDoc.Rebuild
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thank you so much for your response, @MechMachineMan!! I tried it out and it seems to run for a little longer than the ilogic I posted, but the  same error code persists =\
MechMachineMan
Take the s out of the line:
to make
Justin K
Thank you so much!!! @MechMachineMan
