Push add-in to all users
Majjek
Message 1 of 11
Majjek
I've developed an add-in which is almost ready for distribution to all users in our company (~20 users).
What is the best way to do this?
Create an installer and then manually install it everywhere?
And after that, when I make changes, what is the best way to update everything?
Thanks in advance for your ideas.
Replies (10)
Message 2 of 11
AlexFielder
Back in the day, it was possible (using Visual Studio) to "publish" an executable to a shared network location. You'll still see this on certain Windows applications; Google Chrome can do this (depending on where the installer originates).
I've built most of my installers using Innosetup - which is free and relatively simple to get going with; although I've never found an "update" mechanism that works aside from emailing my fellow users on the head and saying "there's an updated installer for {addinNameHere} available at {path}"
I would love to hear other's suggestions though.
Message 3 of 11
bradeneuropeArthur
We have created a .bat file that starts with windows and copies the dll files each time windows starts!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 11
bradeneuropeArthur
like this:
@Anonymous off
xcopy "P:\xx\yy.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\zz.dll" "C:\Program Files\Autodesk\Inventor 20##\Bin\" /y
xcopy "P:\xx\yy.addin" "C:\ProgramData\Autodesk\Inventor 20##\Addins\" /y
xcopy "P:\xx\zz.addin" "C:\ProgramData\Autodesk\Inventor 20##\Addins\" /y
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
Majjek
Thanks for the program.
Message 6 of 11
Majjek
This sounds like an easy solution, thanks!
Message 7 of 11
bradeneuropeArthur
Your thanks are appreciated.
Sometimes we all forget to take a look at the easy way....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
frederic.vandenplas
I Copy the Addin file local (you can use the script provided here) and let that file point to the dll which is on the server, so if i need to update the dll, i just can overwrite it, next time users start up, the new version is loaded.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 9 of 11
Majjek
That sounds even better.
Where is 'here' regarding to the script.
Message 10 of 11
bradeneuropeArthur
P:\xx\yy
P:\xx\yy
P = the server
xx\yy is the path
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
frederic.vandenplas
I was pointing to message 4 from @bradeneuropeArthur
