Punch Tool
Punch Tool
Punch Tool
Hello everyone.
Does anybody knows the name of the punch tool that makes this kind of "emboss" or bridge on the edge of a sheet metal part?
Does even exist on inventor?
I'm tried creating the punch tool by myself but it fails when i put the bridge on the edge and make the flat pattern.
I'll keep trying, just wondering if there is a tool library out there somewhere.
Regards
MechMachineMan
You'll probably get a quicker/better response from the guys in the general Inventor Forum.
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks ! ill post it in the general forum.
