My apologies for this. My knowledge of Ilogic is still minimal. I'm also new here on this forum.
I'm going to formulate it differently.
I have a predefined list of suppliers and manufacturers.
If I have a part or assembly that has to be a purchased part. For example, I enter the purchase part data (123456 DFM-80-200-PPV-A).
And then I want to choose the right supplier and manufacturer from a drop down menu and let both data automatically fill in the properties of the part / assembly.
Supplier and manufacturer is a custom property that I have already created in the part / assembly template.
Each manufacturer has a corresponding supplier.
Below a short list. The real list is much longer (80 manufacturers)
Manufactur Supplier
ELESA SHAKE HANDS
FESTO FESTO BELGIUM NV
NTN IMES DEXIS NV
SMC S.M.C. PNEUMATICS NV
SNR IMES DEXIS NV
TURCK MULTIPROX NV
If I select a manufacturer, it must be possible to automatically fill the corresponding supplier into the custom properties.
Also, it should be possible for me to select the supplier separately (manufacturer will remain empty). Of course, via a drop down menu.
So:
1) 2 drop down menus in the ribbon: manufacturer and supplier
2) The 2 drop down menus contain predefined data
3) If I select a manufacturer, the corresponding supplier must be selected automatically. (Each manufacturer has a supplier)
4) It should also be possible to select the supplier only, manufacturer remains empty.
5) Automatically fill in the selected data in the custom properties of the part / assembly
Also, there must be a possibility that the properties should remain empty (for parts that are not purchased parts)
