- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello there,
This is an ongoing problem I have had for a while, every time it occurs I dutifully send off my error report.
As I get this problem a few times every day Autodesk must have a few now?
question 1) Have you received my reports?
I can lose anywhere between 0 mins and several hours work when this occurs, which I have to redo so I really do not have the time to investigate the problem.
I can say that it happens if I open a model from within a drawing and perform basic edits,eg lets say I notice a hole is missing. To prevent the error I would have to have only the drawing open, close and save it, open the model, insert the hole then rebuild, save and close that, then reopen the drawing.
question 2) Is this how it should be done?
The most annoying failure of all is when I save the drawing and it crashes this too happens at random and seems to be related to opening drawings and models not following the sequence above.
Anyway you should have many error reports generated by me I can send you a model and drawing to try this for yourselves.
