Problem to read open documents
cavallerin
cavallerin
Hi all,
i have the following code that looks for open inventor files, discard what it is not an assembly and prepare a list of selectable document, then data are retrieved from the model and written on an excel sheet.
The purpose of this function is to give the user the ability to say from which assembly he/she can retrieve data.
All is performed within an excel workbook.
The problem I'm facing is:
when I open a new file and run the code, it will not shows the new opened document in the selectable list. It seemes that there's a kind of "cache", but I don't know exactly how it works.
e.g
I open assembly1, run the code, a pop-up windows show in the list the "assembly1.iam" row
If then I open another assembly (assembly2) and rerun the code, only assembly1 is selectable.
How would you manage that?
Michele
I defined as global variable on the module the inventor application
Option Explicit
Dim invApp As Inventor.Application
here's the GetDocumentList function...
Private Function GetDocumentList(ByRef docs As Object) As Variant
    Dim assiemiCount As Integer
    Dim i As Integer
    Dim doc As Object
    Dim docNames, selectedDocName As String
    Dim isAssemblyDocument, selezioneValida, gestioneCiclo As Boolean
    For i = 1 To docs.VisibleDocuments.Count
        Set doc = docs.Item(i)
        isAssemblyDocument = TypeName(doc) = "AssemblyDocument"
        If InStr(doc.FullFileName, "iam") And isAssemblyDocument Then
            docNames = docNames & i & ": " & doc.DisplayName & vbCrLf
            assiemiCount = assiemiCount + 1
        End If
    Next i
    If assiemiCount ....
bradeneuropeArthur
could you share the complete code with us, so that we can test it ourselves?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sure, here you are.
I let only the sub involved in the macro.
Inside the zip there is a excel file named: _code.xlsm
To run it, please:
  1. Start Inventor
  2. Open an assembly with a least one component.
  3. Click the button on the excel sheet
To raise the strange behaviour:
  1. Keep the previous assembly opened
  2. Open a new Assembly with a least one component.
  3. Re-run the macro on the excel sheet
Thanks for any help.
