Print a excel sheet with iLogic rule
Message 1 of 9
Hello
is there a rule too print a excel sheet?
Replies (8)
Message 2 of 9
MechMachineMan
You would need to look at the Excel API to be able to perform functions within excel.
You can start the code with and run through inventor, but you will need to access excel api.
MSDN or a quick google search can probably get you started.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
I have linked the excel tabel to my assembly.
Message 4 of 9
MechMachineMan
Yes.
That doesn't matter. You still need to have excel open, and thus use it's API to give it commands. Everything iLogic/API does with excel is actually accessing the EXCEL API (it's just not visible to the user).
Everything in the inventor API does not support printing excel sheets. This would be done through the Excel Automation object from within the inventor API if it were possible though.
Justin K
Message 5 of 9
MechMachineMan
As it turns out:
https://msdn.microsoft.com/en-us/library/office/ff838253.aspx
Is what you would need to look into. MSDN/Quick google search, as I had said.
Justin K
Message 6 of 9
And i couldnt find a solution 😞
Message 7 of 9
MechMachineMan
You need to initalize Excel and then you can print sheets out using the method in the link I posted.
Justin K
Message 8 of 9
I have the Excel
Message 9 of 9
I have the Excel
