POSITION GENERAL NOTE
^_^clovis^_^
^_^clovis^_^
hello,
In an IDW,
I'm trying to change the location of a general note on a sheet. The note has no link with any view.
The Note.location.X and Note.location.Y of the note are note the location of the note in the sheet.
So my question : how can I move a general note?
Yours
AlexFielder
Hi @^_^clovis^_^,
If I understood your question correctly, the X & Y values you mention are in cm, not mm perhaps that is why the points don't seem to match their actual location?
The following example "Move sketch entities API Sample": shows you how to move sketch entities, (I assume the approach for Drawing Notes would be similar):
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-E0B5A220-9712-49AD-AADB-33C2A63DB992
Alex.
^_^clovis^_^
Hello Alex,
Thanks for the info. To modify the location of the General note I modified the X and Y coordinates.
As you point out with the example, using the move method might be the way to go.
I'll try that as soon as possible.
Thanks again
Yours
Clovis
