Populating default parameter with newly created parameter using iLogic
eugene.morales
eugene.morales
I would like my parts template to contain the iLogic rule to populate the default parameter with the newly created parameter.
Default Parameter;
O_L = 1
O_W = 1
Newly Created Parameter;
d1 = 300 (may vary depending on part size)
d2 = 300 (may vary depending on part size)
The iLogic should read the default parameter if the newly created parameter is not created yet. Once it is created, it will automatically populate the default parameter.
I'm still a beginner using iLogic and I wanted to learn more how to create my own rule. Hopefully I could manage to create and share in this forum.
bradeneuropeArthur
I don't understand what you try to do.
Isn't it easier to add these parameters to your template per default, instead of adding them with illogic?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
clutsa
Are you looking for something like this?
For Each param In ThisApplication.ActiveDocument.ComponentDefinition.Parameters
	If param.Name = "d1" Then
		Parameter("O_L") = d1
	If param.Name = "d2" Then
		Parameter("O_W") = d2
Next
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
eugene.morales
I've set a couple of custom parameter which is the O_L & O_W then if I create a plate with Length(d1) & Width(d2) parameter that is the time I will derive d1 & d2 to my custom parameter. Instead of manually deriving them I would like iLogic to automatically derive it for me. I hope it's clear as mud. ☺
eugene.morales
Thank you very much for your help.
