Perform a task, ignoring locked parts.
I have a rule that looks through the parts in an assembly, and if it finds the rule its looking for, runs it in the part before moving on. Problem is it does it through locked parts too. How can I get it to skip the locked parts? Im guessing it has to do with adding the vault reference?
SyntaxEditor Code Snippet
Sub Main RunPropertiesRule()
    'Set reference to Document Counter
    Dim oDocCount As Integer
    'Set Document Counter to 0
    oDocCount = 0
    ' Get the active assembly document.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Vault = AddReference "Autodesk.DataManagement.Addin.Vault.dll"
    Dim oVault As Object
    oVault = Vault
    Auto = iLogicVb.Automation
    Dim iLogicAuto As Object
    iLogicAuto = Auto
    Dim oDoc As Document
    oDoc = ThisApplication.ActiveDocument
    For Each oDoc In oAsmDoc.AllReferencedDocuments
        'Increase oDocCount Counter by 1 within For loop
        oDocCount = oDocCount + 1
            If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Dim rules As Object
            rules = iLogicAuto.rules(oDoc)
                'Remove rules
                If Not (rules Is Nothing) Then
                    For Each rule In rules
                    ruleName = rule.Name
                        If Left(ruleName, 3) = "ipr" Or Left(ruleName, 3) = "Ipr" Then
                            auto.RunRule(oDoc, ruleName)
                    End If
                    Next
                End If
            End If
    Next
End Sub
 In the code you can see where I tried to add the reference but it gives me an error "End of Statement Expected", It works fine without
    oVault = Vault
Any suggestions?
By a 'locked' part do you mean one that is read-only ?
Yes, one that has been released in Vault.
TONELLAL
When you try to modify a part (by the macro), if you work with a Vault project you'll have the message to check it out. If it is already checked out, you can only modify it locally, you can not check it in. So even if your macro has modified the part, in Vault the part is not modified. Finally, you waste time to modify parts you cannot check in, but your Vault part is not modified.
bradeneuropeArthur
Use the fileinfo object file readonly= true or false to slip the task. Like:
Dim fio as fileinfo()
If fio.readonly = false
Do the task
End if
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Here is my complete Code to loop throught the assembly, only for files that are write enabled!
Public Sub SaveAllDesign(oTopDoc As Document)
        Dim fioTop As System.IO.FileInfo = New System.IO.FileInfo(oTopDoc.FullFileName)
        If fioTop.IsReadOnly = False Then
            Dim oInvDoc As Document
            For Each oInvDoc In oTopDoc.ReferencedDocuments
                Dim fio As System.IO.FileInfo = New System.IO.FileInfo(oInvDoc.FullFileName)
                If fio.IsReadOnly = False Then
                    'MsgBox(oInvDoc.FullFileName)
                    oInvDoc.Save()
                    If oInvDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                        Try
                            SaveAllDesign(oInvDoc)
                        Catch ex As Exception
                        End Try
                    End If
                    If oInvDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                        Try
                        End Try
                    End If
                End If
            Next
        End If
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
