Parts Only Quantity
Parts Only Quantity
No aplicable
1.417 Vistas
5 Respuestas
Mensaje 1 de 6
Parts Only Quantity
No aplicable
Hi
We have suppressed parts and unsuppressed parts in one assembly. We used this code in iLogic
ThisBOM.CalculateQuantity("Model Data", oCompPartNumber)
But this code for "Model Data" gives us  total quantity of suppressed and unsuppressed parts.
Then we used this code in Inventor API
quantity = ThisApplication.ActiveDocument.ComponentDefinition.BOM.BomViews(1).BomRows(1).TotalQuantity
 But this code gives "1"
We need a code for quantity of unsuppressed parts in Inventor API
Thanks for replying
0 Me gusta
Soluciones aceptadas (1)
1.418 Vistas
5 Respuestas
Respuestas (5)
Mensaje 2 de 6
wayne.brill
I asked a colleague in Inventor Engineering and he confirms that the Inventor BOM is stored in the Master Level Of Detail and suppression can only take place in a non-master LOD. This effects behavior in the Inventor API including iLogic.  (you can see this in the user interface too)
Here is an approach to consider:
Have two rules. Run this rule with the custom level of detail current:
' Change this to the parts you want to suppress
Component.IsActive("Part_WB_2-24-16:2") = False
Component.IsActive("Part_WB_2-24-16:3") = False
Then switch to the Master level of detail and run this rule to get just the non suppressed occurrences:
ThisBOM.Export("Structured", "BomExport.txt", kTextFileTabDelimitedFormat)
'Change this to the parts in your assembly
quantity = ThisBOM.CalculateQuantity("Model Data", "Part_WB_2-24-16")
MessageBox.Show("Number of Part_WB_2-24-16 Not suppressed = " & quantity, "Title")
This works because the iLogic  Component.IsActive("xxxx") = False statement not only suppresses the component, but also sets the BOM Structure to Reference. This takes it out of the BOM. So even though there are no suppressed components in Master, they will still have their BOM Structure set to Reference.  That’s the same in all LODs.
The ThisBOM.Export statement is required to make sure that the BOM is up to date before trying to get a quantity out of it.
If you want a change so that you could directly get the suppressed parts in the Inventor API please log it on the Inventor idea station:
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232/tab/most-recent
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
0 Me gusta
Mensaje 3 de 6
tolgay.hickiran
Hello Wayne,
Do you suggest us using a For Each loop for all sub assemblies and picking the master LOD, because our assemblies are automated with ilogic and some vb.net coding.
The actual case is that, we have a full parametric model, and we get all the sheet flat patterns from a third party program. It takes the iproperties and put it on the .dwg s(or .dxf s).
Can you explain
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
0 Me gusta
Mensaje 4 de 6
wayne.brill
Solución aceptada
I would suggest not using the BOM functionality in the API if you are trying to only count the occurrences that are not suppressed. (This would be in a non Master level of detail).
The AssemblyCount VBA example in the Programming Help iterates through the occurrences. You could use the Suppressed property of each occurrence to get a count of the parts that are not suppressed. You could use that approach using the Inventor API in an iLogic rule.
This DevBlog post could also be useful:
http://adndevblog.typepad.com/manufacturing/2015/02/list-suppressed-components-in-lod.html
Let me know if there is a problem using this approach.
Wayne
Wayne Brill
Mensaje 5 de 6
tolgay.hickiran
So Wayne,
We ended up typing the code and its working. Only thing left is to count for different part names. Thank you very much.
Sub Asd()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Debug.Print oAsmDoc.DisplayName
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = oAsmDoc.ComponentDefinition
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
Dim Occurrences As ComponentOccurrences
Dim i As Integer
i = 0
For Each oOcc In oAsmDef.Occurrences
If (oOcc.Suppressed) = False Then
Debug.Print oOcc.Name
i = i + 1
End If
Next
MsgBox (i)
End Sub
Tolgay Hickiran
Founding Partner
SignatureSignature
website
0 Me gusta
Mensaje 6 de 6
tolgay.hickiran
Dim oOkka As Document
'oOkka = ThisDoc.Document
oOkka = ThisApplication.Documents.ItemByName(oRefDoc.FullDocumentName)
Dim oOccs As ComponentOccurrencesEnumerator
oOccs = oAsmDef.Occurrences.AllReferencedOccurrences(oOkka)
Dim p As Integer
p=0
'Dim Occurrences As ComponentOccurrences
For Each oOcc In oOccs
p = p + 1
End If
Next
every other p value gives us the TotalQuantity
Thanks again Wayne,
Tolgay
Tolgay Hickiran
Founding Partner
SignatureSignature
website
0 Me gusta
