PART LIST SORTING
PART LIST SORTING
Lupe_Stewart
PART LIST SORTING
Lupe_Stewart
I is there a way to sort a parts list automatically with the part number, in numerical order, and auto sort on update. this is one of those things that are repetitive, and would like to omit from sheet to sheet.
bradeneuropeArthur
dim a as drawingdocument = thisdrawing.document
dim PartsList as Prartslist = a.activesheet.partslist.item(1)
PartsList.Sort( "Part Number", true )
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Dim a As DrawingDocument = ThisDrawing.Document
Dim partslist As PartsList = a.ActiveSheet.PartsLists.Item(1)
partslist.Sort("Part Number", true )
Part Number = CASE SENSITIVE!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Lupe_Stewart
thanks for the reply..... when i put the rule in it gave this message:
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
rhasell
Hi
as @bradeneuropeArthur mentioned, the Part Number is case sensitive, so however it is written in your parts list, that is how you must specify it.
The Autosort is tricky, that took me a while to find, but I have just done it for my needs, so I thought I would share it. You need to use the "sort2" option to enable the autosort.
partslist.Sort2("PART NUMBER", True, AutoSortOnUpdate :=True)
Reg
2026.1
