Open all components drawings and export to PDF and DXF
chris.kayD65LB
chris.kayD65LB
Hi I am looking for a piece of iLogic which will do the following;
From the open assembly
Find all subsequent parts and assemblies in the file
Open the drawing for each
Export to PDF and DXF (based on preset configurations)
Close the drawing for each, check back into vault.
Running Inventor 2022
Any help is appreciated
Ralf_Krieg
Hello
I would suggest to use the search function. This will lead you to some threads with similar questions. Something like this one this one  or this one
R. Krieg
RKW Solutions
www.rkw-solutions.com
bradeneuropeArthur
@chris.kayD65LB
Are you using Vault?
This would give you opportunities.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hello-
There is an app in the App store that will make quick work of this. The App is called Fyenite The interface is super easy. See this youtube video for how its done: Exporting Multiple CAD files
Good Luck
