pack and go with drawings vb.net
Best
I cannot find a solution how I can take the dwg drawings with me. These are in the workspace but in a different folder.
I have to change this rule. But I don't find the information. I tried
  the full code
 oPacknGo.AddFilesToPackage(path,sRefFiles)
path stands for the location of the folder. But this gives an error 😞
Do you know of a possible solution or where I can find more information about how it works?
        Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent
        Dim pAth1 As String
        Dim pAth2 As String
        Dim pAth3 As String
        Dim fileReader As String
        fileReader = My.Computer.FileSystem.ReadAllText("C:\Users\epls\Desktop\PATH.txt")
        Dim paths As String() = fileReader.Split(New String() {System.Environment.NewLine},
         StringSplitOptions.None)
        'Dim paths As String() = fileReader.Split(vbLf)
        pAth1 = paths(0)
        pAth2 = paths(1)
        pAth3 = paths(2)
        Dim oPacknGo As PackAndGoLib.PackAndGo
        If (Not System.IO.Directory.Exists(pAth2)) Then
            System.IO.Directory.CreateDirectory(pAth2)
        oPacknGo = oPacknGoComp.CreatePackAndGo(pAth1, pAth2)
        ' set the correct project file.  otherwise, the method will crash
        oPacknGo.ProjectFile = pAth3
        Dim sRefFiles = New String() {}
        Dim sMissFiles = New Object
        '  Set the options
        oPacknGo.SkipLibraries = True
        oPacknGo.SkipStyles = True
        oPacknGo.SkipTemplates = True
        oPacknGo.CollectWorkgroups = False
        oPacknGo.KeepFolderHierarchy = True
        oPacknGo.IncludeLinkedFiles = True
        '  Get the referenced files
        oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles)
        '  Add the referenced files for package
        oPacknGo.AddFilesToPackage(sRefFiles)
        ' Start the pack and go to create the package
        oPacknGo.CreatePackage()
thank you in advance
bradeneuropeArthur
 Public Sub PackAndGoSample(a As String)
        'SET THE APPLICATION TO 64 BIT
        Dim fio As System.IO.FileInfo
        Dim dirio As System.IO.DirectoryInfo
        fio = New System.IO.FileInfo(a)
        dirio = New System.IO.DirectoryInfo(fio.Directory.FullName)
        Try
            MkDir("C:\Temp\PackAndGo")
        Catch ex As Exception
        End Try
        oPacknGo = oPacknGoComp.CreatePackAndGo(a, "C:\Temp\PackAndGo")
        ' Set the design project. This defaults to the current active project.
        oPacknGo.ProjectFile = "C:\Vault\XYZ.ipj"
        Dim sRefcingFiles = New String() {}
        ' Set the options
        oPacknGo.SearchForReferencingFiles(sRefFiles, sRefcingFiles, False, dirio.Parent.FullName & "\_Dwg")
        'oPacknGo.AddFilesToPackage(sRefFiles)
        'oPacknGo.AddFilesToPackage(sRefcingFiles)
        Dim xa = New String(sRefFiles.Length + sRefcingFiles.Length - 1) {}
        sRefFiles.CopyTo(xa, 0)
        sRefcingFiles.CopyTo(xa, sRefFiles.Length)
        'oPacknGo.AddFilesToPackage(sMissFiles)
        oPacknGo.AddFilesToPackage(xa)
        'MsgBox(xa.Length)
        oPacknGo.CreatePackage(True)
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
thank you very much I could use the code in my code. Thanks again
Another question is there is a place where you can find more explanation how to approach certain functions of inventor in vb.net.
bradeneuropeArthur
what do you exactly mean?
Help>>>Programming/API help>>>>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
jakew4ZK5X
hey mate, did you end up solving writing a code that works in VB.net?
ILU
hi Ewoud ( @Anonymous ),
can you help us with packAndGo to make it run from iLogic API?\
or,
can you Share with us you Vb.Net code that you have managed to make it work ?
Ionut 😉
